Old 08-30-2009, 07:13 AM   #1
BDandTTs's Avatar
2005 22' International CCD
Huntington , Vermont
Images: 49
Running light leaks
Don't know why I've put it off for so long, but it is finally time to tackle the condensation that continually accumulates inside the running lights of our 2005 CCD. I know from previous posts that Lewster was offering a kit that included appropriately sized O-rings and screws, but I've been unable to contact him.
Would appreciate knowing the exact specifications for O-rings and screws necessary to seal these lights, or alternatively a current contact to Lewster (whose contributions are missed).
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 08-31-2009, 02:03 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, remove one of the screws and take it to your favorite hardware store. Buy one screw, of the exact same size, made out of stainless steel, for every light you have. Then you need one stainless steel flat washer for each screw. And finally "O" rings that fit onto the screws. Install with the flat washers on the screws first, then the "O" rings, so the "O" rings are against the plastic lense. The washer prevents the "O" rings from slipping over the screw head. Do not over tighten and crack the lense.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-31-2009, 04:39 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Used the same solution, it has taken care of most of the moisture.
The foam gaskets tend to slip around and gluing them to the base and a thin coating of dielectric grease on the edge of the lens has helped. (also in the bulb sockets)
You won't regret the stainless replacements when it's time to change a bulb in a few years. IMHO this should be done at the factory.
Have been told that the only way to stop it completely is removal and re-sealing of the base. que-see?
An auto parts or big box home store should have the o-rings and screws you need. The rings I used were R-01, 1/8th ID, 1/4 OD.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-31-2009, 07:10 AM   #4
BDandTTs's Avatar
Images: 49
Thanks a lot. I'll go shopping soon.
BDandTTs
Running light problems Wayner 76 Lights - Interior & Exterior 3 05-29-2008 07:30 AM
running light corrosion altamont Lights - Interior & Exterior 4 05-20-2008 08:03 AM
Running Light Leaks bhunt Lights - Interior & Exterior 4 05-15-2006 11:18 AM
Running light question jcferguson Lights - Interior & Exterior 9 11-01-2005 09:07 AM
Interior light/leaks Punky General Interior Topics 3 02-22-2003 11:32 AM
