Originally Posted by charlesk
We have a 2016 30’ International. I need to run a 12v line from the fuse box to under the kitchen sink (other side of coach).
In many Airstreams, there is a metal channel under the floor, street side to curb side, in the center, just forward of the wheel wells, through which wires run. It comes out in our Classic inside the kitchen cabinet and under the dinette bench.
On the wire sizing, you should follow:
- ANSI/RVIA Standard for Low Voltage Systems in Conversion and Recreational Vehicles, which tells you to size wiring based on NEC Table 310-13, or
- ABYC E-11, Table VI.
I most strongly recommend that you only use UL 1426 certified marine cable, which meets the 105C temperature requirement specified by Airstream for DC wiring. Most AC electrical supply wiring (like THHN) is only rated to 90C - so you need to use MTW/TEW wire if not the UL 1426 marine wiring. I use Ancor or similar marine primary wire or duplex cable, which is available via Amazon and many other vendors.
Is this to be a new circuit in addition to the existing Airstream circuits? If so, don't forget the new circuit breaker.
73/gus
