Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-21-2015, 02:34 PM   #41
RumbleStrip's Avatar
1984 31' Excella
Cottage Grove , Minnesota
Inner Ceiling Skin Demo
in order to take down the ceiling we had to bend and ruin the trim, so that is what we did.
Tim used a chisel and I used a flat head screwdriver. We started at opposite ends and met in the middle.
For more detailed info check out our blog post on Ceiling Skin Demo.
Meg
Read more about our Airstream, Alice on our blog Rumble Strip Ramblings.
Instagram: @rumblestripramblings
RumbleStrip is offline   Reply With Quote
Old 08-21-2015, 02:37 PM   #42
1984 31' Excella
Inner Skin Demo
This is where we left off on Saturday. On Sunday we dressed project appropriate instead of weather appropriate. It was hot working in Alice in the 78 degree heat with long sleeve and pants, but after all the itching and discomfort from the insulation demo on Saturday we knew it was better to be hot than have our skin covered in that awful pink insulation!
http://rumblestripramblings.com/wp-c...6/IMG_1316.jpg
https://youtu.be/wSKFz0-B9mI
After the skin was down we were left with mice nested insulation.
More info and a video of the skin demo on our blog.
Meg
Old 08-21-2015, 02:40 PM   #43
1984 31' Excella
More Inner Skin Demo
Our goal this weekend was to get the rest of the inner skin off on the curb side. And like every other steps of the demo, we greeted with an obstacle right off the bat. We couldn’t remove the skin on the left of the door where the light switches and lock were because we needed to be able to lock up Alice and we were not ready to play locksmith. Our other obstacle was that we couldn’t get the skin out with out removing the door casing/trim. This wasn’t as big of a deal as we thought it would be. Just like so many other steps to this process we just had to take it one puzzle piece at a time.
Then with the help of the crow bar he very carefully removed the door casing/trim. The last thing we wanted here was to bend the casing because finding a replacement or trying to bend it back correctly would be tough.
More info and photos on our blog.
Meg
Old 08-21-2015, 02:41 PM   #44
1984 31' Excella
Progress!
Meg
Old 08-21-2015, 02:44 PM   #45
1984 31' Excella
More skin demo
So many wires!
Mice nests everywhere. Yuck!
More photos, info and even a video are on the blog post.
Meg
Old 02-11-2016, 07:37 PM   #46
1984 31' Excella
Front End End Cap Demo
The Front end cap is our practice end cap. We do not plan on using this end cap again. Our plan is to move the rear endcap to the front end cap because it is better and more functional storage.
Tim took apart the radio and took down lights.
Finally we were down to just the end cap.
And then many drilled out rivets later...
Read more and see more photos on our blog
Meg
Old 02-11-2016, 07:40 PM   #47
1984 31' Excella
Rear End Cap Demo
The plan is to use this more functional end cap in the front of Alice. The storage is better and the end cap, as a whole, is in better condition. We will still have to plastic weld a few places where it has cracked, but in theory, that will not be too big a deal…. famous last words.
You can find video and more photos and info on our blog.
Meg
Old 02-11-2016, 07:44 PM   #48
1984 31' Excella
Alice's Awning
We are so lucky and happy that the awning looks great. It just needed a bit of a cleaning!
I love the cheery blue stripes.
Meg
Old 02-11-2016, 07:54 PM   #49
1984 31' Excella
Vulkem to the Rescue
Thank you Thank you Thank you Air Forums for all the recomendations of Vulkem. It works great!
Meg
Old 02-11-2016, 07:58 PM   #50
1984 31' Excella
Wire Demo
Between the extensive water damage, the fact that there was a small army of mice that chewed through most of the wiring to make homes in the walls, and the moldy insulation covering every inch of stripped wire, we made the decision to scrap it all and start from scratch. With all the inside skins off, we would never have better access than we do now.
It is amazing the difference it made to get rid of those wires. Alice looks so much cleaner now and we are almost to our blank slate.
Next, we just need to finish up waterproofing (including around the doors and windows), do another water test and then we are ready to remove the rotted out subfloor!
Meg
Old 06-21-2018, 02:44 PM   #51
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
What happened to Alice? New floor, new paint, new interior rebuild?
Matt
rugjenkins is offline   Reply With Quote
Alice :: 1971 Airstream Sovereign International StingrayL82 Airstream Registry Discussions 0 08-19-2011 08:30 AM
Alice falling down the rivet hole... fotochop Ribs, Skins & Rivets 5 12-09-2007 03:26 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
road ramblings norbert Off Topic Forum 4 06-28-2004 11:44 PM
Misc. ramblings till Our Community 14 03-06-2004 07:11 PM
