Old 10-03-2016, 06:41 AM   #1
trthames's Avatar
2018 25' International
Blue Ridge , GA
rubber grommet on shock absorber
Upon inspection of our 2013 Airstream International I found that one of the rubber grommets on the front street side shock absorber is deteriorating (see attached picture). Does this need immediate attention or can it wait until we take her in for servicing?
Thanks for providing opinions!
trthames is offline   Reply With Quote
Old 10-03-2016, 10:48 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Well, there is usually a good amount of debate as to whether that horizontally mounted shock, with its very limited amount of travel, really does much anyway. So performance-wise it is debateable whether it even matters.
I guess your picture failed to attach, so I can't see the condition or the grommet, but the one thought I would have is that if the grommet were completely gone, then the shock would hammer against the mounting stud every time you hit a bump, which could, over time result in breaking the stud loose, and then you have a shock flopping around loose. Granted, this is worst case scenario. So a lot depends on the condition of the rubber (maybe try posting the picture again), and how long you expect to go before having it in for service.
good luck!
Old 10-03-2016, 10:51 AM   #3
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Most of those rubber grommets are a standard size, some are glued in. I would look for a used one from a trash pile at a tire & front end shop
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 10-04-2016, 08:18 AM   #4
trthames's Avatar
Blue Ridge , GA
Thanks!
I appreciate the responses. I'll get it repaired before my next long trip.
Again, thanks!
1" rubber grommet robertel General Repair Forum 3 09-13-2010 06:56 AM
Rubber grommet inlets for black tank? vhord Waste Systems, Tanks & Totes 3 03-20-2008 01:02 PM
1969 Safari shock absorber studs tom westlake Axles 6 06-03-2006 12:03 PM
Shock absorber information Nye Thatcher Shocks 0 02-16-2005 10:49 AM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
