01-31-2011, 06:27 PM
1989 29' Excella
Tyrone
, Georgia
Rotating a 29-footer by hand?
Has anyone out there devised a method to rotate a 29 foot excella 180 degrees by hand(s)? I have an inclined driveway that will be very difficult to back up.
I didn't know where else to post my goofy question, sorry.
01-31-2011, 06:47 PM
Ottawa
, ON
Well, I never use it, but I have a rather large wheel that fits into the nose of my jack. I gather they were a fairly common item back in the day.
Wouldn't that be enough, assuming the grade where you would make the turn isn't horrendous...? There must be many of them hanging around in dusty garages.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
01-31-2011, 07:24 PM
1989 29' Excella
Tyrone
, Georgia
I wonder if that would work. I even have a slight grade that will help move it in the right direction. I will ask some local trailer shops if they have one tomorrow.
Reading on a boat forum also mentioned using a 4 wheeler or a riding lawn mower, although I have neither.
01-31-2011, 07:38 PM
1989 29' Excella
Tyrone
, Georgia
Just a thought. Since friction of the tandem wheels appears to be the primary problem even for the people who have purchase power dollies I wonder if it would work to position the trailer tires onto something like 2 layers of high mil tarp or plastic with dawn dish soap between the two layers.
01-31-2011, 07:47 PM
1972 25' Tradewind
North Vancouver
, British Columbia
You can always pick yourself up something similar to this:
Trailer Tug Pro: The Gas Powered Trailer Mover – Trailer Tugs
There are a variety of manufacturers, so do a bit of searching to find something that suits you.
North Vancouver, BC
01-31-2011, 10:46 PM
1989 29' Excella
Tyrone
, Georgia
That sounds far better. There is one on craigslist near me for $500. Maybe that is the answer.
02-01-2011, 12:07 AM
1978 28' Ambassador
Morada
Don't know if this would help your situation, but I bought a front hitch receiver for our tow vehicle (TV) so I can park our AS by mounting the trailer coupler to the front bumper and drive 'forward' to 'back' the trailer, if that makes any sense...
Using this method helps in backing, but you still need a 'spotter' at the back of the trailer as you now don't have any mirrors to help you...
Ray & Pat; Morada, CA
02-01-2011, 06:52 AM
Lots of good ideas. I'd stay away from the tarp and dish soap.
Be usre you have a way to control the trailer if it starts to roll or slide down your slight incline. Sometimes they're easier to start moving than to stop.
Be careful.
02-01-2011, 07:03 AM
2003 25' Safari
Yakima
With a tandem axle, you could temporarily remove the rear axle's wheels and then put the tongue jack on a floor jack...it'll spin right around. This is how I move my tandem flatbed trailer to fit in its designated parking spot.
Marc
02-01-2011, 07:04 AM
1965 17' Caravel
brooklyn park
backing up the drive
Since the neighbors usually park across from the end of my driveway, I pull the trailer in and then I park it far enough from the garage door to jockey the car in and out. I only have to back the trailer when leaving on a trip, and the slanted drive lets gravity do most of the work. Also, the trailer is harder to steal with the hitch facing the garage. I post a sign on the inside of the service door" trailer in driveway" when it's camping season so I don't forget that it's out there( I store it elsewhere in the winter)
joe q in minnesnowda
02-01-2011, 07:18 AM
1972 21' Globetrotter
nc
, North Carolina
i don't know if this will help, but i came upon a mobile home stuch in a curve years back ant the guy layed two sheets of plywood down brushed some oil on them, pulled trailer up on them and took a come along and hooked to a tree and jacked it right around to where it could go around the curve.it just slid right around.
02-01-2011, 08:05 AM
Jupiter
Remember the trailers electric brake break-away fail safe is there - have a charged battery and active circuit ready if the move starts to runaway.
The break away switch tosses unrestricted battery current to all the brakes and should not be left on a minute longer than absolutely necessary to QUICKLY chock - block the trailer safely, you can cook the electro-magnet coils relying on it for extended times...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
02-01-2011, 02:49 PM
2000 23' Safari
Vero Beach
I can vouch for the dolly wheel. I have one and move my A/S around frequently with the wheel. Just be very careful because it can get away from you! I chock the wheels so as to allow the trailer to move only a bit at a time. The dolly wheel also saved my butt once when I drove into a coffee shop entrance only to discover there was only 9' clearance and no way to turn around while hitched! I unhitched, moved the TV, and spun the trailer around with the dolly wheel. Hitched back up and quickly drove off, not that there was much "face" to be saved.
02-01-2011, 03:14 PM
1974 31' Excella 500
Charleston
, South Carolina
Just hook it to the back of a riding lawn mower and make a tight turn.
If backing it in makes it scrape or whatever, won't pulling it out make it scrape as well?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
02-01-2011, 05:22 PM
Retired.
, At Large
GoJacks
Just get some Go Jacks, and slide them under the trailer's tires. They each have 4 heavy duty casters that will pivot in any direction. Between them and a wheel on the tongue jack, you should be able to pivot and move your trailer anywhere reasonable.
02-03-2011, 09:34 AM
1989 29' Excella
Tyrone
, Georgia
Thanks for the help everyone! The problem is that I have a very steep driveway. Backing it up means I almost break my transmission due to numerous stops up the hill (I seriously need a backup camera) I like the go jack idea. Thanks everyone.
02-03-2011, 09:46 AM
nc
, North Carolina
thats why i love a 4x4 , just put it in 4 low range and idle up a steep drive, my drive is steep also.
02-03-2011, 10:00 AM
1977 Argosy 24
Milltown
, Wisconsin
Why not put a receiver hitch on the FRONT of your tow vehicle. Then put a trailer ball on the front of the TV and back the trailer up your driveway with the tow vehicle going forward. Then you can see exactly where you and the trailer are going, and you don't need to leave room to extract the tow vehicle from behind the trailer after it's parked.
02-03-2011, 11:16 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
No way I would want to fool with a 29' trailer by hand or with a lawn tractor. I had a boat trailer roll down a slight incline when I was moving it one day and that was enough for me. Have not seen your situation, but I would take the WD bars off and try to back it. Or go with a front mounted hitch for parking.
