Old 08-30-2019, 09:59 PM   #1
2018 23' International
Guilford , Connecticut
Rooftop Dometic crazy
Was working fine when we towed her home a year ago. Tried testing the roof top a/c heat pump today and it shakes the roof and and makes a very loud vibrational racket as if it was missing a cylinder. Any ideas?
Pop & Mimms - because our grandchildren say so
2018 23FB International Serenity "Pimm's Cup"
2019 Tundra
Pimms is offline   Reply With Quote
Old 08-30-2019, 10:29 PM   #2
2012 Avenue Coach
Corpus Christi , Texas
Can you safely go up and take the cover off to look inside? Sometimes mud daubers like to nest in there. Could be a nest on a fan blade sending it way way out of balance. Worth a look.
rowiebowie is offline   Reply With Quote
Old 08-31-2019, 01:01 AM   #3
1988 Argosy 32
Lomita , California
if you do go up take a can of wasp spray with you and watch from afar, they will be Pi---d
off to have the home doing 2500 rpm ?.
Wolfe is offline   Reply With Quote
Old 08-31-2019, 05:39 AM   #4
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 121
Had a similar issue and found a huge tree frog bouncing around off the fan. What a mess.
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 08-31-2019, 06:03 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
YEP...Them daubers love the "mouse wheel".
I soak the nest so I don't damage the blades.
After the first time it happened I had some straightening to do.🥴
POI...they also like the exhaust tube of the furnace 🦟
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 08-31-2019, 08:13 AM   #6
2019 30' International
Pennsylvania , Pennsylvania
I'm going with the mud wasp. Climb up there, stay on the seams (follow the rivet lines), don't crawl on the endcaps, and remove the a/c shroud. Locate the squirrel cage fan. Look real close because some times they are hard to find. Probably attached to the inside of the fan wheel some where.
The one time I had this issue I removed the mud nest with a thin screwdriver.
With that being said, it could be something else, but in my experience the old mud wasp would be the first thing to check for.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 08-31-2019, 02:12 PM   #7
Thanks all. I’m hoping it’s that simple. Will check when I can get up top.
2019 Tundra
Old 08-31-2019, 02:32 PM   #8
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Originally Posted by Pimms View Post
Thanks all. Iím hoping itís that simple. Will check when I can get up top.
I'm going out on a pretty fat limb...and saying that's your problem.
Also, you can take off the shroud without getting on the roof. Just do each side at a time, leaning a ladder against the trailer with a towel or blank or foam pull noodles or whatever, protecting the trailer.
pcskier is offline   Reply With Quote
Dometic AC unit driving me crazy franklyfrank Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-20-2016 08:36 AM
How do I clean rooftop ac unit? Chasmorgan Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-21-2009 12:24 PM
How to add Coleman rooftop AC to '72 Argosy 20 airfoil Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-05-2009 12:29 PM
Airstream Trailer Park Rooftop Hotel grantb4 Airstream Lifestyle 1 03-06-2009 08:35 AM
Removing rooftop AC unit: how? davida Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-17-2008 09:35 AM
