Old 03-08-2015, 02:18 PM   #1
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
Roof repair help.
I had a branch from a neighbors tree pierce a hold in the roof on my airstream. Any ideas on how to repair the damage.
ID:	233854   Click image for larger version
tcrum is offline   Reply With Quote
Old 03-08-2015, 02:26 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would cut out the mangled aluminum, cut a patch out, apply some calk, and rivet or screw it down.
Up high like that a well applied patch will be hardly noticeable.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 03-08-2015, 02:29 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The "right answer" would be to get a new panel. Do you have insurance?
If you don't have insurance, I suppose you could screw or rivet an aluminum panel over the damaged area once you've smoothed out the damaged area. You should put a generous amount of caulk on the underside of the panel around the edges and then around the edges after you rivet it in place. You will need to maintain the caulk bead around the edge on a regular basis as caulk tends to dry and crack.
Bob Martel
WBCCI# 5766
Old 03-08-2015, 02:49 PM   #4
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
How much do you want to spend to "fix" it? If you want a good patch that won't break your wallet, get some Eternabond Alumibond in the 4" or 6" type. You could clean up that area nicely (metal bends and cleanliness), fasten the edges down with some blind rivets where the original seam was (or use some aluminium sheet metal screws, Apply some ParrBond to the seam and any torn area, then cover the area with the Eternabond tape. Being on the roof, I would not be inclined to spend a ton of money getting it to look like new, however the Eternabond will give you a seal that will hold for a long time.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
