Old 05-08-2016, 07:07 AM   #1
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Rodent no more. 67
Before I put the new floor in my trailer and it still sat outdoors, it was not uncommon to see chipmunks etc... climb the safety chains then go in the A-frame and from there into the the belly of the trailer to chew stuff up.
I decided to make some removable covers for the problem areas at the tongue.
The covers are aluminum and held in place with the crazy strong velcro pictured. It's only 1/16" thick too.
I ran the break away switch wiring through the back cover.
The back cover is pressed in then held in place with the riveted on tab velcroed to the frame.
It's not perfect but it will be tougher for the critters to get in.
ID:	262127   Click image for larger version
Dingo Girl is offline   Reply With Quote
Old 05-08-2016, 07:09 AM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Good idea, and nice job!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about" Rod Stewart (Faces)
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 05-08-2016, 07:33 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good Morning Dingo Girl. It's been a while. You made it through another winter, although not as bad as some Michigan winters can be.
Those open A-frame channels under the coupler has always been a nemesis of mine. Mouse front door to my Airstream. I should put a little welcome mat out. I made little 5 by 1 1/2 aluminum "end caps" for mine and pressed them into the open channels. It helped. This area is also where rain water enters the frame rails and settles into the belly pan area while towing in a rain storm. Water scoops! The infamous rear bumper storage compartment and body to C channel seal is also a great place for a mouse to sneak in the "back door", as will as rain water to get into the belly pan area. (I call it my Airstream basement, and yes, it gets wet at times.)
There are so many mouse entry points in an old Airstream. I try to get them closed up, but I still get a mouse or two in my traps inside the Airstream. I'll bet the bottom of your trailer is as tight as a boat hull.
Your solution to the open A-frame channels is elegant! Hand crafted to fit perfectly.
David
Old 05-09-2016, 04:01 AM   #4
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you both for the kind words.
I was going to make caps too but decided on this route. The only place I could have gotten at to cap off those channels was inside the trailer where the 7 way umbilical comes into the belly.
I did not want a rodent nesting in the A-frame in the 4 feet or so of "tube". Or should I call it HabiTrail?
Old 05-09-2016, 06:45 PM   #5
Manitou Springs , Colorado
Two of we four are kitties. Unwelcome visitors beware!
Don, Melody, Rocky and Phoebe
06' Tacoma Crew Cab 4 Liter Turbo
'72 Argosy 20
1Tigress 1Tux
Don Doucette is offline   Reply With Quote
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
? rodent-damaged wiring mmcpherson General Repair Forum 9 12-26-2009 11:05 AM
Rodent steals the spotlight kevin242 Fun & Games 3 08-15-2009 05:06 PM
Try This For Rodent & Moth Control KANEHILL Winterizing, Storage, Carports & Covers 3 10-22-2007 03:28 PM
Rodent-proofing for storage zimbop Winterizing, Storage, Carports & Covers 10 10-05-2007 07:54 AM
