Old 11-20-2014, 09:42 AM   #1
dznf0g's Avatar
Oswego , Illinois
RockTamer fix
Because I have to adjust my RockTamer quite frequently, due to several different TV combinations, the plastic area which inserts into the aluminum yoke has gotten chewed up to the point of having to cut off about 5" of the material at the end. This makes the rod too small in diameter to clamp the yoke down on.
I made sleeves out of .019" sheet aluminum for a fix.
Just an FYI, if you run into the problem.
-Rich-
Old 11-20-2014, 11:30 AM   #2
2016 30' Classic
Erie , Colorado
Rich not sure I understand what plastic section you mention. A photo would help.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 11-20-2014, 12:15 PM   #3
dznf0g's Avatar
Oswego , Illinois
Guess I didn't explain well. The plastic sleeve over the rod that holds the flaps and is mounted into the aluminum yoke had to be cut away.
-Rich-
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
