Old 12-05-2019, 12:08 PM   #1
2004 25' Classic
Hanahan , South Carolina
Rock guard not flush at top?
Is this normal or is there anything I can do about it?
It is flush at the bottom but the top of both has a fairly large gap...
ID:	357281   Click image for larger version
Planenut is offline   Reply With Quote
Old 12-05-2019, 12:14 PM   #2
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Mine is like that too. Other than catching leaves and pine needles, it does protect from road debris.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 12-05-2019, 05:14 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
It is doing what it was meant to do, protecting the windows from flying objects. They all fit this way, and open them up and clean behind them a few times a year. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 12-05-2019, 05:49 PM   #4
2002 19' Bambi
Lafayette , California
The rock guard does not have the compound curvature of the body of the Airstream behind it.
Tim
Tim A. is online now   Reply With Quote
Old 12-05-2019, 06:10 PM   #5
LilBigfoot's Avatar
2016 26' Flying Cloud
London , Ontario
Get a piece of that grey, copper water pipe insulation from HD. Cut it to the length of the top of the guards, spread apart and slip over the edge..now you can keep from getting needles, leaves collecting back there. Get the larger diameter one.
You're a long time underground!
LilBigfoot is online now   Reply With Quote
Old 12-05-2019, 07:52 PM   #6
2004 25' Classic
Thanks for all the responses. I was worried I had a problem!
Old 12-05-2019, 09:38 PM   #7
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Our 2009 Classic is the same. They are to stop rocks from hit the glass not keep things from falling between it and the glass. I too wished for better fit.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 12-06-2019, 11:34 AM   #8
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Just throwing this out there:
1. Could it be because the way it has to swing out?
2. Could it be because of aerodynamic?
3. Could it be because it is small effort to save pine needles for your fire starter?
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 12-06-2019, 03:58 PM   #9
2002 19' Bambi
No to all three. As I stated above, the rock guard has a curve in a single plane and the body of the Airstream behind it is a compound curve. Bending the rockguard frame and the plastic sheet it holds into a compound curve would, in no way, improve the performance of the rockguard. A compound curve would look cool, but add even more expense to what one pays for an Airstream. No, I don't think the company is being cheap, but surely somebody will come back with that common remark .
Tim
Old 12-06-2019, 04:37 PM   #10
2017 16' Sport
Canyon Country , California
I had same thing until I added the PVC pipe insulation. Just needed 2 foam pipes. Be prepared to cut to fit. I just put the foam at top, not at bottom.
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 12-13-2019, 09:11 PM   #11
2017 25' Flying Cloud
Woodway , Texas
Just curious: why use weatherstrip on the back of the rock guard in the first place if it doesn't seal the gap? Doesn't improve aerodynamics. Some on our 2017 is beginning to loosen and periodically has to be reattached...
emelaich01 is offline   Reply With Quote
Old 12-14-2019, 06:30 AM   #12
2018 25' International
Slidell , Louisiana
The "seals" are primarily there to absorb shock thus prevent scratches and other damage to the body when they flex due to wind gusts and contact with objects. There is intentionally a lot of flex in the rock guards, if they were stiff they would shatter much more easily when hit with a rock. This is likely one big reason they don't have compound curvature which would make them much more stiff.
Brian
Rock Guard Shield over glasses does not fit snuggly on Airstream Halford1 Windows & Screens 26 11-06-2019 01:09 PM
Front Curbside stone guard -Front Sun guard Projet2907 Windows, Doors, Locks & Vents 0 02-06-2018 08:26 AM
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 04:00 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 08:32 AM
If it's NOT a rock guard, what is it called? tiniree Rock Guards, Segment & Window Protectors 7 05-14-2003 06:52 AM
