Old 08-16-2015, 08:35 AM   #1
2015 22' FB Sport
Medford , Oregon
Road Tar
Does anyone know of a good way to remove roar tar that has splattered onto the trailer body?
GaryRus is offline   Reply With Quote
Old 08-16-2015, 11:35 AM   #2
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Pledge furniture polish in the spray can.
The Ice Man is offline   Reply With Quote
Old 08-16-2015, 11:36 AM   #3
Central , Mississippi
Ive had good luck with a heat gun and mineral spirits BUT mine has no clear coat. If everything else fails I'd try very low heat and go slow, the heat softens the tar, a plastic putty knife will gently slide it off and mineral spirits remove the remaining slime.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 08-16-2015, 12:44 PM   #4
Nomad518's Avatar
2001 25' Safari
Ridgefield , Washington
Spray it with WD40. Let it soak a short while. Then, gently wipe it clean with a soft rag. Don't rub vigorously because there could be grit in the tar that could scratch the surface of your AS. The WD40 should melt the tar away. Any road tar cleaner from an auto parts/supply store would work just as well.
Nomad518 is offline   Reply With Quote
Old 08-16-2015, 01:58 PM   #5
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I think airstream recommends using kerosene? a clean rag and a little kerosene worked for me.
Hiho Silver is offline   Reply With Quote
Old 10-17-2019, 09:24 PM   #6
2016 22' Sport
Davis , California
removing tar spatters from clear coat surface
I've read this thread and wanted to make sure we try the right way to remove the spatters without damaging the clear coat. Although, since they were hot when they hit the surface, the clear coat may already be damaged? Is goo gone safe for a clear coat surface?
tjelson is offline   Reply With Quote
Tar looking spots on floor tundra07 2009-2015 Flying Cloud 5 05-16-2016 08:23 PM
??? How To: Remove Black Tar / Re-Seal ??? TxBxSx Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 04-08-2013 11:58 PM
Pitch and road tar Orson Cleaning, Stripping & Polishing 4 09-30-2011 09:09 PM
tar removal? lisa.bivens General Repair Forum 17 07-10-2008 03:37 PM
removing leak "fix" of PO (tar) obxairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-17-2008 05:33 PM
