Old 05-03-2016, 08:47 PM   #1
1988 34.5' Airstream 345
Camarillo , California
RM3801 refrigerator won't cool
We just bought an Airstream 345 LE 1988. The refrigerator indicator lights all work and so does the light inside. It knows if it has AC or Propane. However, it won't get cold and freezer isn't working. Pilot light is lit and the back plate is warm to hot. However chilling pipes are air temp. Recognizes when AC is plugged in but that never gets cold.
Looking for suggestions
Thank you
Ren&Quinn
Ripley345 is offline   Reply With Quote
Old 05-03-2016, 09:09 PM   #2
1986 31' Sovereign
Miami , Florida
Classic symptoms of a failed cooling unit. Either the plumbing is corroded and obstructed preventing the ammonia evaporation cycle from functioning or the unit is perforated.
You can have it rebuilt or order a rebuilt cooling unit yourself and install it -- I did it with my wife in about 2 hours and the hardest part was removing the reefer to get access.
If you decide to replace the whole unit, you might consider going with a marine Danfoss compressor unit. Work on 12vdc, very efficient and generally accepted to be safer.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-03-2016, 09:57 PM   #3
I am handy but never done cooling systems. How hard is it? Is it easy to convert to Danfos How would I know which size to get?
Thank you,
Ren
Old 05-09-2016, 09:03 AM   #4
2011 23' FB Flying Cloud
Tallahassee , Florida
Dometic RM2551 Refrigerator
I also have a problem with my Dometic RM2551, five years old. Not cooling. I checked all fuses, the heater element is OK. Have plenty of propane and am plugged into 30A electric. I can purchase a rebuilt "coil" cooling unit for about $500 and do the replacement myself. However, I have never pulled a fridge from an 'RV and am reluctant to jump in. I've learned that a new unit plus labor will cost around $1,300. Any recommendations?
1Cruzin is offline   Reply With Quote
Old 05-09-2016, 08:23 PM   #5
1986 31' Sovereign
Miami , Florida
Removing the reefer seems to be different year by year and model by model. Mine had two screw on either side on the front frame and one on each side on the rear of the unit holding the base frame to the deck.
So, gas line off, AC unplugged, DC wires removed, screws out and slide unit forward. Yours may be different...
The actual cooling unit replacement is pretty easy.
Mike
Young, lovely bride
Old 05-09-2016, 09:15 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Thank you,
Ren
Both Isotherm and Virtifirgo make add-on Danfoss cooling units that enable one to convert any insulated space into a DC operated fridge/freezer. Depending on the interior size of your fridge box, you might need a BD-35 or possible the larger BD-50 compressor and cold plate kit.
Given the age of your refer, I would not sink any further $$$ into it as your gaskets are probably worn as well. I would look into a full replacement marine fridge and you will never again worry about the poor cooling capabilities of any ammonia/absorption fridge again.
And the best part..........no more 'RV soft-serve' ice-cream!!!!
Dometic 2510 won't cool on gas 68 TWind Refrigerators 11 05-03-2016 10:02 PM
Fridge won't cool on gas keithwade Refrigerators 2 07-31-2010 09:41 AM
Refridge in 72 Tradewind won't cool RichHog Refrigerators 14 03-01-2009 07:22 PM
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
Thrown out at home plate! need RM3801 controlboard Jetstreamer Refrigerators 3 05-16-2008 06:09 AM
