Old 08-26-2016, 10:14 AM   #1
1995 30' Excella
Lakeway , Texas
Rivets
Could someone explain rivets to me in laymans terms? I know about 'pop rivets' but they are not used on airstreams correct? Do you replace them if they pop out? What kind, how?
Yes, I am a newbie (5000 mi and counting), with a 95 that is updated inside and stucturally sound, but 'rough' on the outside.
jbs411 is offline   Reply With Quote
Old 08-26-2016, 10:32 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Solid round head rivets are the type used on the outside body of an Airstream. This type of riveting requires a two man team and full access to the interior. Blind rivets or pop rivets are utilized on the interior panels of an Airstream. These rivets require access to only one side. Hit up Uncle Google. There are some good explanations on line with photos and drawings.
Brian
SuEllyn & Brian McCabe
2005 Suburban 2500 Quadrasteer (Olivia) & 2011 Silverado 3500 (Fred) with Outfitter Truck Camper (Ethel)
Old 08-26-2016, 10:33 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Basically pop rivets are used in a lot of applications in Airstreams.Pop rivets do not "pop out" the term comes from the pop noise when they are installed. They are also called blind rivets because you can't see the inside surface when they are installed. The rivets you see on the exterior skins of Airstreams are bucked rivets because you have to have access to the inside surface when installed and use a bucking tool (usually a 2 person job)
Old 08-26-2016, 11:08 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Re: pop rivets, Recommend using all alluminum rivets like vintagetrailersupply sells. They can be difficult to sometimes find locally.
MICHAEL
Old 08-28-2016, 07:22 AM   #5
1995 30' Excella
Lakeway , Texas
Thanks for the response..Maybe I should have asked it this way....If an exterior buck rivet comes out/head breaks off/becomes loose, can you replace them with pop rivets?
(bucked rivets need the other side exposed, pop rivets may leak?)
Thanks again
Old 08-28-2016, 08:09 AM   #6
2002 30' Classic S/O
1989 25' Excella
2014 Interstate Ext. Coach
Missouri Valley , Iowa
Exterior rivets are replaced with "Olympic rivets". They are a nice variation of pop rivets, but are shaped like the buck rivets. They need to be shaved after they are in place to look like a buck rivet, though. This requires a rivet shaver or lots of patience and skill with a Dremel.
Dan
Farmer Dan is offline   Reply With Quote
Old 08-28-2016, 09:44 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Thanks again
This begs the question, why did the bucket rivet come loose? Is there excessive towing vibration?
Old 08-29-2016, 10:18 AM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 97
Here is an old post of mine that shows pictures of the different kind of rivets...hope this helps.
Rivet Types - Post #14
Basically there are three different kinds of rivets:
Bucked Rivets - Solid and strong - BUT, you must have access to both sides of the rivet in order to install them. Also, in most cases, a second person to help install them. These are the kind that were originally used on your Airstream exterior.
Olympic Rivets - three legged with heads that look like solid bucked rivets, if they are shaved properly - can be installed w/o removing interior panels. These are often used as replacements for bucked rivets when you don't want to or can't dismantled your entire interior to access the back side of the panels being riveted. Not as strong as bucked but strong enough for most small repair projects and/or non-structural uses.
Pop Rivets - the kind you can get at the hardware store, they have a stem & hole in the center - can also be installed w/o removing panels but were only used on the interiors of vintage Airstreams. They aren't nearly as strong as the other two types.
Shari
Old 08-29-2016, 03:28 PM   #9
1995 30' Excella
Lakeway , Texas
Great question...Just a few up on top, the heads came off...not sure why....22 years of vibration?
Old 08-29-2016, 04:52 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
Ordinary vibration should not cause rivets to pop, even on trailers a lot older than yours. Did they pop recently? Try riding in the trailer while it is being towed at various speeds. The vibration should not be excessive or something is wrong with your running gear.
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 02:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
