Old 08-30-2015, 12:29 PM   #1
Spicewood , Texas
Rivets
Hello
I have a 2013 25 Flying Cloud and have found approximately 10+ rivets on the floor.
The Dealers tells me that this is only convered by warranty for 2 years.
Anyone have this problem. The Dealer has "never heard of this"
Did not find in forum.
Thank you
Larry
lwb9 is offline   Reply With Quote
Old 08-31-2015, 12:00 AM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Did you notice any missing rivets in the vicinity (from any of the interior panels)?
If you don't see any missing rivets, do you have a close friend who would pull this kind of prank on you?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 08-31-2015, 05:29 AM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
That would be a funny prank. When I pulled up the old carpet and padding in mine there were mandrels all throughout the coach. (about 20 or so) I just cant imagine that not being found on one of the inspections.....
NavyCorpsman is offline   Reply With Quote
Old 08-31-2015, 07:27 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Interior rivets will come off on any Airstream on a periodic basis. 10 all at once seems a bit excessive. Is there any pattern to the popped rivets? I.e., are they along a single rib line or around a single door or window? This type of pattern might indicate a structural issue. On the other hand, if they are randomly distributed throughout the coach I would not be overly alarmed at this point. Drill out the old rivets and replace them with the proper rivets (aluminum rivets with ALUMINUM mandrels) and monitor the situation.
You can Google replacing pop rivets, there are several very good YouTube videos on how to do this.
Bob Martel
WBCCI# 5766
Old 08-31-2015, 07:56 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The roadways are rough, it's not unusual to lose one now and then. Ten of them suddenly breaking loose is excessive and a symptom of out of balance running gear (tires, wheels, hubs), or too rigid sway control bars connected to a too rigid suspension on the tow vehicle if you just changed either one or both.
I would start by rebalancing the tires if all else has been the same since Airstream was new, then look into reasons for excessive vibration.
Doug and Cheryl
Old 08-31-2015, 08:04 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My trailer is almost 10 years old. I am still finding construction trash in nooks and crannies. I recently found several phillips bits when I removed the front couch sandwiched between the couch and interior wall. Figure that they must of fallen out of the pocket of a tech during construction. Best find was several credit cards, unfortunately they are many years expired.
MICHAEL
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 02:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
