Old 10-10-2013, 07:33 AM   #1
Beavercreek , Ohio
riveted patches?
I am looking at a trailer that has what appear to be small riveted patches on the curbside and driver side back corners. (I've tried to attach a picture.) I think that I've read that this kind of repair may indicate skin or structural problems. Or are they not really patches? Can anyone shed some light on this?
szalonna is offline   Reply With Quote
Old 10-10-2013, 07:38 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
In a perfect world we all have unlimited funds to make perfect repairs to our trailers. The cost difference between that patch and an entire new panel can be $$$$.
MICHAEL
Old 10-10-2013, 07:42 AM   #3
aquinob's Avatar
Portsmouth , Virginia
Could just be a patch due to a hole, tear or dent in the aluminum. Not to say there are no other problems but I wouldnt say that one or two patches are unusual. Just look to see that they sealed it well or evidence that water may be getting around it.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 10-10-2013, 07:47 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Those are probably elephant ears to patch over a repair site to correct tail droop. Correcting the problem requires access to the area where frame meets tail at the rear. Accessing the area can be done either by removing all rivets from the area of that rear panel and moving it out of the way, or by cutting a hole into that panel and patching it afterwards. It's cheaper to cut the hole, but less aesthetically pleasing, obviously.
Lynn
WBCCI 21043
Old 10-10-2013, 07:48 AM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You mention 2 patches on the rear corners... could it be one patch to cover a small blemish in the location pictured, and another mirror-image patch to make the first look like it belonged there?
My current project is going to require several little patches to correct for a previous owner's unhealthy obsession with sheet-metal screws...
David
Old 10-10-2013, 08:00 AM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
How cool is that! You've got zero excuses to open/inspect/maintain that area now!
Old 10-10-2013, 08:05 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Lynn
This was part of a factory fix for tail droop in the early70's. There were also reinforcing plates that were put on in the axle area. Your picture looks like a trailer older than that but it looks like some one was reattaching the body to the frame.
When Airstream did it they opened up a larger area so I would guess this was done by a previous owner.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-10-2013, 08:54 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Ask the owner if it is ok first; then have someone stand on the bumper and bounce up and down, this is a test to see if the repair is still holding. If the bumper moves separate from the body it is not (this is rear end separation) If it moves up and down as one unit, the repair is still good. You will need someone with you to watch for the movement because the person bouncing may not be able to notice the differential movement.
Alan
Old 10-10-2013, 06:47 PM   #9
Beavercreek , Ohio
Thanks everyone for your insight and advise. Tail droop was what I was vaguely remembering. I will do the bounce test if I look at this trailer again.
Old 10-13-2013, 05:40 PM   #10
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Open the rear hatch and look at the inside. If there is a plate, wood or metal on the floor that was an attempt to fix the separation problem. They needed to bolt through the U channel-plate-floor-frame between the int/ext skins. That patch was the easy way to access. Short term half azzed fix. Not a big issue if the rest is reasonable condition and you intend a rebuild anyway.
putback is offline   Reply With Quote
