Originally Posted by Maximo
..what is the correct size drill to use to drill out the rivets so you do not over size the holes? Where do you get the rivets to replace the ones taken out? Where can I get a gasket ...Also is there a spell check function on here? My blushing bride is is tired of spellchecking for me ... Kevin
Drill size is #30 if you're a purist, 1/8" otherwise.
You can get the rivets at Home Depot. If you want them with a white top rather than aluminum color, order from Vintage Trailer Supply. I'm sure there are other sources.
You're going to have to make your own gaskets. If you can't find thin rubber material, use butyl tape, available a most RV parts places. It's like plumber's putty, but waaaaay better.
Yes, there is a spell function, a checkmark with ABC over it up in the upper right corner of the gray window where you compose your posts.
Zep
