08-25-2013, 07:05 PM
1976 27' Overlander
Gray
, Tennessee
Rhino lining
Anyone have any thoughts on rhino lining seams from inside when doing a restoration? I was thinking that stuff would probably work great to seal seams. Just curious.
08-25-2013, 09:12 PM
1999 34' Excella
Hillsboro
Hmmmmmmm.....
Interesting thought...on seams or all over?
Peace and Blessings..
Channing
WBCCI# 30676
08-25-2013, 10:03 PM
Hollis
, New Hampshire
08-26-2013, 04:42 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by reinergirl
No experience with it but wondered the same thing....know it's tough, but how flexable?
Im done with adulting
Lets go find Bigfoot.
08-26-2013, 05:31 AM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
You know if you can float on a screen door sprayed with this stuff I'd think it would do a great job on the interior seams. They claim these remain flexible due to the rubber nature of the product. We've thought about using "flex seal" on interior seams as well...
Indiana, PA
PA TAC-5
WBCCI-4871
08-29-2013, 07:28 PM
1966 17' Caravel
Newport
, North Carolina
Flex seal cost too much and you are not able to use half of the can before it seals itself and no longer useable. Rhino liner is not flexible a enough (it will delaminate. Undercoat may work but just the difficulty of removing it would make me question my sanity. Let us know if it works. As for us Tempro it is.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
08-29-2013, 07:30 PM
1966 17' Caravel
Newport
, North Carolina
Sorry for the poor grammar I am tired and the iPad spell check is guessing!
08-29-2013, 08:37 PM
Tenkara Fly Angler
1975 31' Sovereign
Vernon
We use this in the beds of our service trucks. Not as flexible as you would think in a hard attach point. Example: a 2001 pickup that had Rhino Lining with a detachable spray rig it took years to develop cracks, gouging. 2013 truck with Rhino Lining, 4 months developed gouging/cracks at hard attach points. Same installer, and warranty is being used now. From personal experience. Either they changed the formula or our local installer did. I am now not depending on after warranty, going to use our installer to coat our hard attach point bed inserts with the same lining. From what I see, the formula has changed from previous applications.
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
08-29-2013, 09:51 PM
1976 28' Argosy 28
Dallas
Keep in mind if a product is made to be applied to the bottom of a vehicle it should probably not be used inside. I've used the Rust-Oleum product. It smells like tar and doesn't go on thick. Very thin application unless you do multiple coats.
I was told about this product. It's used to stereo applications. I think I'll try it because it kills sound and is made to be used on the inside of the vehicle. Lizard Skin.
http://www.summitracing.com/parts/liz-50100/overview/
http://www.summitracing.com/parts/liz-50115/overview/
08-30-2013, 04:23 PM
1976 27' Overlander
Gray
, Tennessee
This is all good stuff!
08-30-2013, 04:46 PM
1999 34' Excella
Hillsboro
Doooods. They use on roof,,,, waterproof!!!
Channing
WBCCI# 30676
10-22-2013, 10:12 PM
1999 34' Excella
Hillsboro
Folks,
Received following from Lizard Skin coatings..
Channing,
Thanks for your interest in LizardSkin, Where you can Spray your way to a Cooler, Quieter Ride.
LizardSkin Ceramic Insulation (CI) can be applied anywhere heat is a concern example firewall, ceiling, floorpan, under hood and inside doors. Being a spray on application you can completely encapsulate the entire interior and exterior areas like the floorpan of the vehicle, you can reach difficult areas that other products can't go. In your case applying to the exterior roof of the travel trailer is a great application. This will create a complete thermal barrier we can cool a vehicle by 30°. It also creates a seamless moisture barrier.
We do make LizardSkin Ceramic Insulation in White, Just ask for "CI" in White. You can get it here just call the main line and whoever answers can help you.
Marx Henry
Automotive Specialist
713-465-0304 Office
713-465-0302 Fax
www.mascoat.com
www.lizardskin.com
Channing
WBCCI# 30676
10-23-2013, 06:17 AM
1981 31' Excella II
New Market
, Alabama
If it is a ceramic it is not flexible by definition. It may have particles of ceramic in it but nearly all paints do since the pigments are based on metal oxides which are ceramics. When I hear the term ceramic, my snake oil detector goes off.
Perry
10-23-2013, 06:27 AM
1999 34' Excella
Hillsboro
Originally Posted by perryg114
If it is a ceramic it is not flexible by definition. It may have particles of ceramic in it but nearly all paints do since the pigments are based on metal oxides which are ceramics. When I hear the term ceramic, my snake oil detector goes off. Perry
Probably so, just sharing info as received. Same as "hoppin charades", I.e.; hoppin' shame..ER..hop and change
Channing
WBCCI# 30676
10-23-2013, 08:06 AM
2010 25' FB Flying Cloud
Davenport
, Iowa
what about using Kool Seal both inside and out? It's flexable.
10-23-2013, 12:03 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Kool Seal makes a variety of products, not all of which are necessarily flexible. And they're not designed for use on moving objects; they're designed specifically for flat roofs or low-slope roofs on commercial buildings. And they're not designed for inside use, either.
They make a product specifically for aluminum roofs, but it's an asphaltic coating which would be ugly as sin on the roof of your Airstream.
Their flexible coatings— the elastomers— are very fragile. If you brush your Airstream's roof with a low-hanging limb, you'll tear the elastomeric coating to shreds. Their elastomeric coating is nothing much more than a spray-on or brush-on roof condom.
11-11-2013, 04:09 PM
Graham
I used ArmorThane in the back of my truck. It is flexible so it might be a possible candidate. The other nice thing about it is it comes in different colors.
