Old 05-23-2019, 05:27 PM   #1
1975 Argosy 26
Corrales , New Mexico
Revamp of 1975 Argosy
Hi there friends,
After almost a year of having her and trying her out, yesterday we began the process of revamping our 75 (or 76 depending on where you look) Airstream Argosy 26'. We love the current layout which works for our family of six with a few minor tweaks. Though this is our first camper restoration we are not necessarily green in all areas. My husband and I have flipped several houses and built the home in which we are now living (with lots of help from family). Our list our "before" goals which could change as we delve deeper into this project:
1. remove and replace most of kitchen and bath cabinets (leaving one overhead bin)
2. Paint interior and exterior
3. Flooring
4. Replace appliances, toilet, water heater, furnace, axels
5. reconfigure booth seating in front to U-shaped seating that will hopefully accommodate two adults when broken down to a bed.
6. take off and clean out belly pan
surprises after one day of demo:
1. both black and fresh water tanks are above the subfloor along with all the water lines
2. subfloor damage under the shower/tub pan
3. venting configurations seem excessive
4. found a fun vintage sign from our trailer's past life
We were hoping to go full monty or even mess with skins but with the discovery of the rotted corner, I am curious of our options. We are so thankful for this community and people's willingness to lend their expertise and experiences! Cheers!
Leah and Jay
rushhome6 is offline   Reply With Quote
Old 05-23-2019, 08:25 PM   #2
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Welcome! Glad the 26’ works for you. I ended up going to a 30’ since we couldn’t make the 26’ work for our 3 teens.
The placement of the door makes a U shape dinette a little less efficient (one side is a bit shorter) but several have done so.
If the only floor rot is that corner - LUCKY YOU! you can repair just that section and no need to go full monte. Be sure to check any hidden areas, particularly at water lines or external access doors.
When you pull the bellypan you can inspect the frame from below. Oh and be sure to wear goggles, a mask and full body covers if you have them ... it gets messy under there.
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 05-24-2019, 02:03 PM   #3
1975 Argosy 26
We were lucky with the layout- though it’s only 26’ it has the double bunk twins which is the only way I see fitting a family of six. If we were going full time, it might be a different story but we’ll be using it as a bunkhouse for camping and road trips where we’ll mostly be outside. We are finishing the demo on the bathroom today and then we’ll have a fuller picture of what needs to come out.
Old 05-26-2019, 04:54 PM   #4
1977 Argosy 24
That looks like a very similar layout as our 1977 24' twin bed model... the "front room" as I call it on ours seems to have a different layout, but close. Did your twin bunks come from the factory as bunks or were they retro fitted that way? I am planning on turning mine into bunks and was curious how they did it in yours? Good luck with the referb and keep posting pictures, sounds like we are at similar stages of work and it would be nice to follow along! We found a couple mementos from her previous life as well... i think we are going to frame them and use as decor. ��
Wingnutt is offline   Reply With Quote
Old 05-27-2019, 08:07 AM   #5
1975 Argosy 26
Wingnutt- yes these were factory bunks. They’re very clever imho. The top bunk is hinged to the wall with a swing arm and the bunk itself is two separate pieces joined in back with a hinge so the lay flat when in the bunk position or folds up under itself in the goucho position. The bunk position is supported by two straps which attach to the ceiling. The beds fit my teenage (adult sized) kids just fine- they actually fought over who got the top bunks
ID:	341765   Click image for larger version
Coach Battery revamp Vycan Mechanics Corner - Engines, Transmission & More... 2 03-01-2016 04:17 PM
1988 Excella repair/revamp Timbojr General Repair Forum 9 04-07-2013 04:24 PM
66 Overlander Revamp in Progress NWOverlander General Interior Topics 45 03-21-2008 01:32 PM
Foam Insulation? Aluminum? Loose Curtain Rails? Revamp Goucho? 74Argosy24MH General Interior Topics 4 02-03-2005 08:39 PM
