Old 08-12-2016, 04:12 PM   #1
1972 25' Tradewind
Walker , Michigan
Retrofit stabilizers to vintage AS?
We have a 1972 Tradewinds 25ft. Right now I use those useless and frustrating screw style stabilizers. They don't work that well, too much play in them as they are designed.
I would love to install some stabilizers I can raise and lower easily that will help hold trailer still a little better.
What are you using on your vintage AS? How do they get installed? Where are best spots? I really don't want to have to drop the belly cut holes.
Complete Overhaul/Resto'd 1972 Airstream TradeWind Land Yacht 25'
TV= 2002 Jeep Grand Cherokee 4x4 4.7L V8 128k miles
Docster is offline   Reply With Quote
Old 08-12-2016, 04:21 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I use BAL stabilizers, original equipment of many Airstreams, including my 1979 Safari.
I believe you need a special long reach one on an Airstream.
Bill
Just my personal opinion
Old 08-13-2016, 11:44 AM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
sissor jacks , appx 80.00 a pair , make sure u get the 1's that have 3/4" hex drive .
mount where diamond is behind rear wheels , 4 x 1/4" self tapping hex drive bolts 1" long works fine takes about 40 minutes for pair . thes will also help level trlr and with a flip socket can use 1 x 1/2" brkr bar / ratchet to both level and pull flat tire ! just makes more sence than a stab jack that can't pick up weight.
crestonrv is offline   Reply With Quote
Old 08-13-2016, 12:42 PM   #4
1972 25' Tradewind
Walker , Michigan
Do you have a link to these? I really like the idea of them being able to lift in an emergency.
Old 08-13-2016, 10:10 PM   #5
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I have the Bal jacks installed as discribed above, they work great.
As for changing a tire if you have tandem axles just drive the good tire up a ramp block , this will take the flat tire off the ground so you can change it.
BTW if you need to get off the highway fast just remove the bad tire and drive away on 3 tires according to Airstream.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 08-13-2016, 11:15 PM   #6
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
I don't think it is wise to "lift" an airstream with the stabilizer jacks especially in the rear.
Al Boondy is offline   Reply With Quote
Old 08-14-2016, 07:37 AM   #7
1966Florida's Avatar
1966 26' Overlander
Orlando , Florida
I bought the scissor style jacks from camping world- ($75-$80 per pair). I use my Ryobi 3/8" cordless impact with 19 mm socket. Works like a dream. Trying to use the long hand wrench while bending over in the dirt, sand mud etc is like wrestling a toddler under there :-)
I feel that these scissor style jacks have 2x's the lifting capacity as the fixed mounted on the newer A.S models. maybe the newer fixed mounted jacks are better but I was not impressed with the older ones+ I dont like something fixed mounted hanging under there while traveling down the road. adds more weight and looks bad on Vintage.
I purchased 2 more scissors on Amazon. These were about the same price however the jack screw had coarser threads on this set- which reduced the lifting power so I use these 2 for the front and allow the Elect Tongue jack to help out if needed. ( Which this T.J is one of the best things that I swapped out to date!!)
If possible...Try and get the finer thread jacks.
Pick up some Ryobi 18V cordless tools at H.D.- I carry the rechargeable flashlight Cordless drill, and impact in my tool bag every time my trailer leaves my driveway.
1966 Florida
1966Florida is offline   Reply With Quote
Old 08-14-2016, 08:54 AM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We also use the stabilizers that fit in between wheels, if you're tandem. It eliminates most of the movement that is left after the stabilizers are deployed. We worth the money.
Kay
Vintage porch light retrofit LHall Lights - Interior & Exterior 19 05-21-2018 10:00 AM
Retrofit electric stabilizers (eg Power Twin II) on vintage trailer? Jacob D. Repairing/Replacing Floor &/or Frame 10 07-04-2007 12:18 AM
BAL stabilizers losing nuts? Kistler Jacks, Stabilizers, Lifting and Leveling 3 04-15-2004 06:50 PM
BAL Stabilizers kamadeca Jacks, Stabilizers, Lifting and Leveling 1 11-28-2003 12:32 PM
