Hello again folks!
Okay so so am finally getting around to replacing the sub floor in our 2007 28ft safari. I am guessing the rot is due to the dreaded bumper sill area leak. The previous owner sold it too me knowing of the damage but had it covered by a tarp in the rear access hatch
but i am partially to blame for not looking under it...none the less i do not think fondly of the person who sold me the AS.
okay to the questions. I really had no idea what i was getting into when i started taking things apart. I am skilled at carpentry and metal working, built my home etc, so i thought this will be apiece of cake.... wrong....
From what ive read you have to take take all the inner skins of off in bedroom area and i really do not wish to do this. I've potentially come up with a solution. The area i need access to will be covered by cabinetry. I see no reason why i cant cut out the section of skin in the attached photo to get access to the frame bolts and then replace with another sheet of aluminium slightly larger. I will never see this area, and i don't care if it doesn't match perfectly.
Am i missing something? could this be done with out affecting the shell integrity?
since im removing and replacing such a small section of the sub floor do i need to worry about the frame dropping when removeing the bolts? I have my balancing legs down would that be enough?
another question as well. are there any detailed write ups showing exactly where to caulk with photos the bumper/rear hatch problem area?
