Old 03-21-2016, 07:28 PM   #1
2015 27' FB International
Prairie du Chien , Wisconsin
Replacing rivets on newer International
My newer 2015 International, 27FB, has lost 4 rivets inside the cupboards on the curb side. Not sure how this happened. I am 1000 miles from home in Louisiana and do have the airstream rivet replacement gun with an assortment of rivets. I think I need to drill out the stem of the rivet, and simply replace them. However the kit has two lengths of the 1/8 " smaller rivet, 3/8" or 1/2", and I am not sure which to use, or if it makes any difference. Or can this wait until I get back to my dealer and have it done under warranty? Thanks.
KJJorgen is offline   Reply With Quote
Old 03-21-2016, 08:05 PM   #2
1994 34' Excella
Warren , Manitoba
Probably either will work, but I would use the 1/2". If you now own an Airstream you might as well start now to learn how to replace rivets!! Interior ones are the easiest. There are lots of threads here on how to do the job. Good luck!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 03-21-2016, 09:06 PM   #3
BassCan's Avatar
2014 27' FB Eddie Bauer
Mobile , Alabama
Foley Airstream is in Gulfport Mississippi, if you are not too far from them, they could do it under warranty.
BassCan is offline   Reply With Quote
Old 03-21-2016, 10:14 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
There is no reason to replace these rivets right now.
Replace these at your leisure!
Some trailers pop rivets while others will never loose one.
Stop worrying and have a great trip.
You need not buy the very expensive rivet gun from Airstream. A $5 gun from Harbor freight will pop a rivet just as well as a $100 factory gun.
Lowest and HD or any hardware store sells the guns as well as the aluminum shank pop rivets.
Old 03-22-2016, 02:22 PM   #5
Safari Streamer's Avatar
2015 28' Flying Cloud
Ladson , South Carolina
rivets
We just had a few replaced at our dealer for our 2015, under warranty. Always easier to have the pro do it!
Kathy Narowski
#2555
SC Coastal Unit
TAC-SC5
Safari Streamer is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
