Old 10-15-2013, 05:50 PM   #1
theboyzmaid's Avatar
1970 31' Sovereign
, West Virginia
replacing interior skin
I thought this was going to be simple, clean a bit, change out a few minor things, and enjoy. The search for a leak or two has my trailer about gutted. Now Im thinking replacing the interior skin with aluminum sheeting, and from what i have seen on the forums, 5050 .040 18 gauge is a good choice. My question is can i replace it in 4x8 sheets instead of the long continuous sheets that are original without compromising structure? It seems to me if I am overlapping on the rib and riveting securely, it should still be ok, but im no architect.
theboyzmaid is offline   Reply With Quote
Old 10-15-2013, 06:03 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I don't see any reason you couldn't
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-15-2013, 07:23 PM   #3
1970 31' Sovereign
, West Virginia
thank you so much...it will be cheaper and easier to do it that way, buying the sheets as i go, this eases my mind and makes my heart a little lighter, lol.
Old 10-16-2013, 01:00 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
I plan to use the longer (17') sheets in mine. I believe I have found a local metal supplier who can get them for me. I think it will be less work. (hang one sheet instead of two)
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 10-16-2013, 07:59 PM   #5
1970 31' Sovereign
, West Virginia
i can only find the 4x8 sheets locally. Im also doing it on a budget, and I work full time with two boys in sports every evening. I will be lucky to get this right as i am definitely not very handy, but i sure am gonna try
Old 10-16-2013, 08:56 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I reskinned my entry door, and now find that every time I touch it, I get at least a finger mark, and at worst (ie., sweaty shoulder bump), a corroded patch. I spoke to the factory and they say they use the same aluminum on the shiny interiors as they use on the exteriors, and this is an Alcoa aluminum with a plastic clear coat that is factory applied. Do y'all plan to do anything to seal your bare aluminum interiors?
Also, on the concerns about structural integrity above, I doubt that the interior skins contribute appreciably to the structure, just judging from the low frequency of relatively weak pop rivets.
Old 10-17-2013, 06:03 PM   #7
1970 31' Sovereign
, West Virginia
can i buy the clear coat and apply it myself? I have no idea, just trying to figure it all out myself
