Old 07-31-2015, 11:20 AM   #15
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
I like this idea and will steal it. Thank you for the clear picture.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 07-31-2015, 11:35 AM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Glad I don't have an AS, again (there are some things I really like). Drain valves on mine are in kitchen cabinet. Fresh water just off of tank and far from tires. Almost shielded. In the older versions, behind exterior access door. That said, the city water connection on one of the old ones was just in front of tires.
These companies did study each other. Frustrating that they didn't all use the best approach after one or the other introduced it. I could list differences and we'd all know the better one.
Nice set of posts. Bookmarked.
Old 08-25-2015, 07:17 PM   #17
2009 20' Flying Cloud
Carlisle , Pennsylvania
Wow! A lot of work. Mine broke when hit by a stone thrown by the tire while traveling to AK. Made a quick fix with plumbers' caulk pushed into the broken stub of the plastic valve. Given the requirement to cut an access in the galvanized pan to replace the broken valve, I decided to see how long the caulk lasted. So far it's been 4 years and all is well. I use the pump to empty the fresh water tank when winterizing w/o problem. Ty
Ty Trainor is offline   Reply With Quote
Old 08-25-2015, 08:49 PM   #18
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
When mine broke, I took it to the Airstream dealer in Albuquerque, NM and had them fix it. Less than $100. Money well spent in my opinion.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 08-25-2015, 10:24 PM   #19
dougandlori's Avatar
2004 28' Classic
Fresno , California
I am ordering one tonight at
RV Fresh Water Drain Valve Flange 3 8" or 1 2" Won'T Fail Ever Again | eBay
I put on in my 95 excella and need one for my 04
You won't be disapointed
Doug
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Replacing fresh water drain valve with aluminum Morgan guy Fresh Water Systems 22 11-15-2014 11:49 AM
replacing fresh water drain valve HeadnOut Fresh Water Systems 5 05-13-2009 10:19 PM
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Fresh water drain valve nilesrob Fresh Water Systems 3 11-10-2006 08:23 PM
