Old 06-07-2012, 02:25 PM   #1
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Replacing CO detector
Well my five years are up. The CO detector is beeping three times every minute to tell me it's time to replace it. It is a First Alert CO350MRVA (battery operated) that came with my AS.
First Alert claims that only their CO250MRVA or CO400MRVA models are currently approved for RVs. But I can't find them for sale anywhere (all I find are 12v models). I can find a CO400 that's battery operated, but not approved for RVs.
So my questions are:
Where can I get one?
Is the "RV rating" real?
Will the non-rv CO400 will just rattle apart sooner (but for $17 who cares)?
Old 06-07-2012, 02:53 PM   #2
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Last October our First Alert that came with our Safari also gave us the signal that it needed replacement. I also found it difficult to find and than found what looked like the identical model except made by Honeywell:
Honeywell Carbon Monoxide Alarm Detector Model #SF350RUL - Batteries Included
I ordered it and it fitted perfectly in the original mounting bracket.
SilverGate is offline   Reply With Quote
Old 06-07-2012, 03:42 PM   #3
Wayne&Sam's Avatar
Images: 21
Thanks SilverGate. It does look identical.
Old 06-07-2012, 03:58 PM   #4
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
SilverGate....That is a great deal at $19.50. I purchased the same detector from Amazon in Nov 2011 under the brand name of Safe T Alert for $49.82.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 06-07-2012, 04:04 PM   #5
SilverGate's Avatar
2007 23' Safari SE
Yes, it was a good deal and works fine in the original mounting bracket.
BTW, interesting "handle" you have "2dabeach"... that's what they say here in San Diego (going to the beach)... but in New Jersey where I grew up we said "going down the shore"!
Old 06-07-2012, 04:13 PM   #6
SilverGate's Avatar
2007 23' Safari SE
You're welcome Wayne&Sam...
Now, if I can just get someone who has 14" aluminum wheels with 5 lug holes and who has installed Centramatic wheel balancers tell me the model/part number that works for them!
Old 06-07-2012, 08:39 PM   #7
rogerdodger's Avatar
Fresno/Clovis , California
Hey silvergate, that was a good catch. I needed one, ordered it right now. Thank you,
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 06-07-2012, 09:08 PM   #8
tpi
Trabuco Canyon , California
Has anyone had one not beep after the five years? My trailer was made in '04 and batteries have been replaced from time to time, but no beeping indicating end of life.
I suppose I should replace it anyway.
tpi is offline   Reply With Quote
Old 07-17-2012, 08:16 AM   #9
sherrylynne's Avatar
2007 23' International CCD
vero beach , Florida
Thank you Silvergate! Ordered it, looks exactly the same, (enclosed batteries were non-functional, but that's ok..I had some correct size)...would like to thank you very much for the info!
sherrylynne is offline   Reply With Quote
Old 07-17-2012, 09:28 AM   #10
SilverGate's Avatar
2007 23' Safari SE
You're welcome, rodgerdodger and sherrylynne...
Thank you for saying "thank you"!
Glad to help.
Old 07-17-2012, 09:47 AM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I can't remember if I've ever replaced the batteries in ours and it hasn't beeped, unless it did it during the winter and finally gave up. I'd better check it.
Gene
Old 07-17-2012, 10:18 AM   #12
2007 27' Classic FB
Ridgefield , Washington
Mine crapped out right on time. Replacement is in.
John & Lisa
Woosch is offline   Reply With Quote
Old 07-18-2012, 11:41 AM   #13
SilverGate's Avatar
2007 23' Safari SE
I believe the life of these CO detectors is programmed to be 5 years and an internal timer will trigger the beeping at the 5-year mark.
Old 08-05-2014, 08:46 AM   #14
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
My COSTAR failed this week after one year of use, although it was manufactured in 2010. Amazon had a lot of bad reports on COSTAR life, many failing early, and bad support from COSTAR. So, I have ordered a Kidde, accompany with a good reputation.
Larry
lsbrodsky is offline   Reply With Quote
