Old 05-09-2012, 07:20 PM   #1
Libo's Avatar
2010 31' Classic
Crestview , Florida
Question Replacing a window on a Safari
Has anyone successfully replaced a small oval window in a 28' Safari's bedroom?
Is there a special way to take the frame apart?
Need to replace the glass. Thanks.
Libo is offline   Reply With Quote
Old 05-09-2012, 08:00 PM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Yes, I did that on my Globetrotter. Doesn't take much effort. Take a sharp putty knife and shave off the rivets putting the knife paralleled to the face of the airstream. Use a rubber mallet. Once you remove the heads you might need to drill out or punch out the rivet stems. The frame and widow will come out. At this point you will have to separate the frame from the glass. I wrote up a post in the window section if you are interested. You can go to the glass shop and a get a replacement tempered glass made to fit. Clean up the old gasket and use vulkum and parabond to reseal the gasket. Re-install with new rivets and you are done. It cost me $50 for my glass. Here is the thread: http://www.airforums.com/forums/f454...ass-79710.html
Rick
montanablue is offline   Reply With Quote
Old 05-09-2012, 09:05 PM   #3
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Hold on a bit...
Libo,
I've replace two "stack" windows on my 1970 Safari, but I think your 2007 glass might be installed a bit differently. I have those same windows in our 2007 International but they look different than the ones in my '70.
Montana is correct in that you can replace yourself ( I center punched the rivets and drilled them out to remove the assembly). But get some input from someone that has replaced your much later version of the same window, they may just be rubber glued in from the inside, not sure.
The '70 safari had a gasket that held it in place within the riveted frame (which comes apart). On our 2007 rig, I see no gasket, just a rubber glue material. You may just have to remove the easy to replace rivets from inside your coach. Again, not sure but much easier than removing outside rivets. As Montana mentions, a glass shop in town should be able to make the glass, temper and tint to match. Good Luck- Let us know what you find.
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
