Old 10-22-2015, 11:41 AM   #1
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
replacement panel specifications
I have just attached my shell and floor after completing frame repairs and floor replacement. My streetside rear corner seems like it will need to have the panel from the back hatch to the side panel replaced. (approximately 42 x 72")
Does anyone know the specifications for what aluminum I need? The '68s used the alclad aluminum which I would like to use as I hope to polish the trailer at some point and want it to all match.....
I have a good local airstream dealer, so can order from them, but also have a good sheet metal shop from which I obtained my bellypan aluminum, just not sure what to ask for.
newas4mark is offline   Reply With Quote
Old 10-22-2015, 01:08 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
.032 2024-T3 Alcad, .040 will give good results also.
Old 10-25-2015, 06:29 PM   #3
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
Thanks, Aerowood.
Old 10-25-2015, 07:26 PM   #4
If you indeed have a 1968, then the quarter panel metal is the same exact material as the basic shell.
It's 2024 T 3, .032 thick and the correct size needed for that quarter panel is 48 inches high by 60 inches long.
You can use .040 material, if you wish.
The correct sealer to use is Vulkem.
You might by the way, have to buy a 4' X 6' sheet especially from suppliers such as Aircraft Spruce.
size specifications atvmcg 1974 - 1979 Safari 11 01-26-2007 09:55 AM
Engine Specifications Chart Howard Lefkowitz Classic Motorhomes 5 10-23-2006 12:24 PM
New and looking for specifications. bill_bravo Member Introductions 4 08-07-2006 08:35 PM
What are the specifications for this model? mello mike 1970 - 1973 Sovereign 7 08-16-2005 11:37 AM
Comprehensive Airstream Trailer Specifications Nicksut Our Community 8 07-26-2005 08:15 AM
