Old 03-23-2012, 06:58 AM   #1
lewishw's Avatar
1978 31' Sovereign
Colorado Springs , Colorado
Replacement latch for fresh water door
The latch on my fresh water access door is broken so I have to use a screwdriver to open and close it. Are replacement latches readily available somewhere?
lewishw is offline   Reply With Quote
Old 03-23-2012, 07:12 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
You might try Outofdoorsmart or Inland RV.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 03-23-2012, 07:17 AM   #3
blmitch5's Avatar
Olathe , Kansas
Here is one from IRV but I'd also check with Out of doors mart.
http://www.inlandrv.com/catalog/index.php?cPath=58
I hope this helps.
WBCCI 4973
Old 03-23-2012, 07:17 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If it's like Lucy's in the below picture, you can get a replacement key lock or non-locking latch at Camping World or just about ant RV parts supplier.
Brian
SuEllyn & Brian McCabe
Old 03-23-2012, 07:31 AM   #5
lewishw's Avatar
1978 31' Sovereign
It's the older style where the inside of the access door helps serve as a funnel to get the water into the tank. It is not a threaded type water fitting. I will post a picture as soon as I get up to the trailer.
Old 03-23-2012, 08:21 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
What year is your unit?
Is it this style:
https://www.makariosrv.com/products/...rue-White.html
Note in the House Door dscluchfc Our Community 32 08-29-2012 05:09 PM
Vulkem 116 and Acryl-R, which do I use for what? Sandi & Bob Leaks - Weatherstrips, Gaskets, Caulks & Sealants 20 03-24-2012 09:00 AM
NY State said no to a vintage plate, Time for a letter campaign. HHaase Airstream Lifestyle 14 03-23-2012 10:30 AM
Split Rims gotta go, is this a correct replacement? Tabasco Wheels, Hubs & Bearings 20 03-23-2012 01:48 AM
