Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-20-2018, 04:31 PM   #1
Modesto , California
Replacement Keys for Entry Door/Water Input door?
Hi all!
I have a 1972 Overlander and i purchased it without the keys. I was wondering if and where I can get the keys for the trailer door and water main and water door?
Is that possible?
I tried looking on Airforums for this and couldn't find an answer for the entry door but let me the link if it's already covered!
Marlin4622 is offline   Reply With Quote
Old 09-20-2018, 04:45 PM   #2
Boxite's Avatar
2008 22' Safari
Your local locksmith would likely have in-stock the simple keys for the water door/lockers/etc. The entry door might require a bit more research, but I'll bet the locksmith can figure it out.
Old 09-20-2018, 06:29 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Originally Posted by Marlin4622 View Post
Hi all!
Is that possible?
If you have a KT lock assembly on the door. It might be the same key as mine. Which is a 733 blank. The water door is 87.
My locksmith made new keys by modifying a blank. Filing it thinner, then cutting the key.
The blanks you get from Out of Doors Mart are not the correct blanks.
Old 09-20-2018, 06:35 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look for a web site Lostakey.net.
They list a number of key blanks for Airstreams of your era.
Old 09-22-2018, 07:11 AM   #5
mama tarrh's Avatar
2004 34' Classic S/O
Indianapolis , Indiana
Jackson center emailed me the key blank number list for our Classic. I took it to our local locksmith and he was able to make all but one which I already had a copy of. Good luck!
mama tarrh is offline   Reply With Quote
replacement keys for main door lock (have number) nickglase Classic Motorhomes 9 06-18-2020 06:23 PM
Leak on around the City Input / Flush input wponder Plumbing - Systems & Fixtures 2 04-09-2018 06:31 PM
Water leaking from fresh water input 3dawgnight Plumbing - Systems & Fixtures 2 10-24-2016 11:01 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Looking for input on floor replacement S C Streamer Member Introductions 2 03-03-2006 10:59 AM
