Old 08-31-2016, 01:04 PM   #1
2007 25' Safari FB SE
Aiken , South Carolina
Replacement for OEM Penguin heat pump
Looks like our Dometic DuoTherm Penguin heat pump has bitten the dust. What's the best unit to replace it, with at least the same 13,500btu?
Allen
awkirch is offline   Reply With Quote
Old 08-31-2016, 01:09 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I went with another Penguin, to keep the low profile and the interior plenum.
The are sold as separate parts.
I also upsized it to 15k btu.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-01-2016, 06:45 AM   #3
Thanks. Mine is the older "Penguin I" rather than the low profile "Penguin II". Do you know if the version "II" will still use the old interior plenum?
Old 09-02-2016, 10:07 AM   #4
jdalrymple's Avatar
Jay , Oklahoma
I can't say for sure, but I wouldn't be surprised if it would work.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 09-02-2016, 01:58 PM   #5
2017 30' Flying Cloud
Spotsylvania , Virginia
Wow, your rig is a 2007 and it just went out?
I have a 2015 and AS is installing the 2nd one this week under warranty.
I will pay the thing off this year and will get rid of the unit, we have had nothing but problems in 18 months of ownership.
KWN306 is offline   Reply With Quote
Old 09-02-2016, 02:16 PM   #6
Getting rid of the Airstream or the A/C unit? Two failed A/C units in 18 months?
Old 09-02-2016, 08:47 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
It will work. I did the reverse on my 2008... I kept the exterior penguin I mechanicals but changed the interior air distribution cover with the one that ships with the Penguin II as part of an over cosmetic update. The old square yellowish plastic air distribution box wasn't doing it for me....
The newer air distribution box works better to cool off the trailer for what it is worth....
wulfraat is offline   Reply With Quote
Old 09-03-2016, 07:44 PM   #8
2 A/C's, one furnace, two refrigerator repairs, then a new refrigerator, a leak in the roof and one water pump. My 23FB International is cursed.
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
Used circuit board for Dometic Duo-Therm 13,500 btu Penguin heat pump. Shayne50 Airstream Classifieds 0 07-09-2015 09:13 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Pls explain the different cycles of a New Penguin Heat Pump! FullTimin2HI Furnaces, Heaters, Fireplaces & Air Conditioning 5 03-16-2011 07:09 AM
Penguin Heat Pump / Thermostat Problems Bob Thompson Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-04-2010 07:06 PM
