Old 08-14-2014, 05:56 PM   #1
streamslave's Avatar
1967 28' Ambassador
Gatlinburg , Tennessee
Replacement AC for a vintage trailer?
I have a '67 Ambassador with a roof-mounted ac unit.
The inside unit condenses quite a bit to the point of it soaking the floor itself even with the windows & door closed. This unit has a copper line attached to it in 2 different places as to drain the pan. ( not stopped up)
Can someone tell me if I decide to change the unit, is it possible to buy one that has the drain line attachment similar to the existing unit?
If not, does the condensing water just run down the exterior of trailer?
I would like to hear some experiences weather good or bad about their installation a vintage trailer.
Thank you,
Jerry
streamslave is offline   Reply With Quote
Old 08-14-2014, 05:59 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The '67 has a two part a/c system, with a couple of relatively small holes in the roof/ceiling. If it works well other than the leaking condensate, I would try really hard to fix the leak before replacing the air conditioner.
Old 08-14-2014, 07:44 PM   #3
e5earley's Avatar
1969 31' Sovereign
Paris , Texas
I reworked the condensate pan on my 69 and am really pleased with the results. As long as yours is blowing cold, I would recommend resealing the pan and keeping it. Here's a link to my renovation showing the work I did to mine.
http://www.airforums.com/forums/f44/69-sovereign-camp-ready-renovation-121865.html
Hopefully yours is not in as bad a shape as mine was. If you decide to repair yours, just be careful about building up material on the inside of the pan. There's not much clearance where the coils sit.
e5earley is offline   Reply With Quote
Old 08-17-2014, 06:50 PM   #4
1967 28' Ambassador
Thank you both for the replies.
The craziest thing... I moved the trailer a little to polish the other side & it is no longer dripping from the pan inside. I guess the trailer has to be completely level.
Vintage Trailer Academy - - - formerly Vintage Restoration Rally Ken J WBCCI Rallies & Events 211 06-06-2016 08:13 AM
1970 airstream, vintage airstream, vintage camper, airstream travel trailer, eBay Watch Airstreams on eBay 0 10-27-2013 08:10 PM
Airstream, vintage trailer, travel trailer, airstream, towable camper, retro eBay Watch Airstreams on eBay 0 09-14-2011 08:30 AM
