Old 09-25-2015, 11:42 AM   #1
2004 25' Safari
East Northport , Ny
Replacement A/C shroud
Hello,
I am trying to buy a replacement shroud for my 2004 safari. It has a Dometic duo-therm Penguin A/C. When I call around, they want a model number. My manual covers several model numbers so I don't know which one I have. I see shrouds for sale that just list as shroud for Penguin A/C. Are all shrouds the same for Penguin A/C's?
Garyj is offline   Reply With Quote
Old 09-25-2015, 11:45 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Why not call the factory ( Airstream). They will surely have the numbers for your year model.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 09-25-2015, 11:50 AM   #3
2004 25' Safari
East Northport , Ny
If there are cracks in the shroud, will rain waiter leak into the trailer or will it get picked up in the pan and diverted out safely?
Old 09-25-2015, 02:05 PM   #4
lewster's Avatar
The base pan is sealed to your roof. No worries about rain leaking into the trailer (unless it has leaked before!).
Lew Farber
541-490-6357
Old 09-25-2015, 02:22 PM   #5
dznf0g's Avatar
Oswego , Illinois
I got a replacement for mine from Icon Direct. I believe one size fits all Penguins. BTW, the Icon is a very nice shroud. Much more UV resistant. I've had mine for 4 or 5 years.
http://www.icondirect.com/penguin-do...ner-shroud-pw/
-Rich-
Old 09-25-2015, 02:26 PM   #6
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down
IMHO.....stay away from Icon Direct in Canada, the customer service sux and if, after delivery your not satisfied they refuse to pay return shipping. After many phone calls they finally gave me a return auth #, they knew full well I wouldn't pay the $130 UPS or 125 USPS.
Some say they are great....but I wanted to paint and replace the Airstream decals, the plastic they use has no bonding properties, can't be painted and decals won't stay on.
BTW......it's for sale.
ID:	248933   Click image for larger version
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-25-2015, 02:28 PM   #7
dznf0g's Avatar
Oswego , Illinois
"If it ain't broke.....fix it 'til it is. "
Now, I guess I know what you mean!
-Rich-
Old 09-25-2015, 03:30 PM   #8
Cool
Yep.....exactly what I ended up diding.
A little epoxy & glass mat, good as new, maybe it'll last another 10yrs.
PFC
"Tahawus"
RLC
Old 09-25-2015, 04:55 PM   #9
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
If you still need to find the model number of your AC, it should be somewhere under the inside cover. Although not a Penguin, mine was visible when I removed the access cover for the filter, above the filter on a tag stuck to the sheet metal.
PaulnGina is offline   Reply With Quote
Old 09-25-2015, 05:12 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Rule of thumb, If it can be sanded, it will hold paint.
Brevi tempore!
Old 09-28-2015, 09:42 AM   #11
Thumbs up
Brevi tempore!
Not necessarily true... HMW Polyethylene not easily coated.
PFC
"Tahawus"
RLC
Old 09-28-2015, 10:00 AM   #12
dznf0g's Avatar
Oswego , Illinois
I wonder if automotive "adhesion promoter", used for flexible bumper covers and the like, would work here.
-Rich-
Old 09-28-2015, 02:20 PM   #13
Rich,
Yes... I believe thats what is meant by "extensive surface preparation."
One internet solution I researched was heating the area with a hair dryer to force the chemicals to the surface, but those chemicals are the very reason for it's flexibility and UV protection...counterproductive at best.
PFC
"Tahawus"
RLC
Old 09-29-2015, 11:33 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hey... sounds like a perfect place to rivet on an Airstream aluminum plate!
Peace and Blessings..
Channing
WBCCI# 30676
Replacement shroud for Coleman Delta TX a/c blackbird Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-03-2013 06:55 AM
1988 Excella Shroud Replacement Needed Airstruck General Repair Forum 2 10-04-2012 06:00 PM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Installing Roof Air Replacement Shroud Kajendo Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-30-2008 12:20 PM
A.C. replacement shroud? krazeekalvin Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-27-2007 12:36 PM
