Old 11-23-2014, 10:17 PM   #1
mommythrice's Avatar
1966 28' Ambassador
Replace bath sink in 1966?
I just realized that the nasty sink in my 1966 Ambassador is a separate piece from the sink base. I'm wondering if I can pull the sink top, replace it with a corian or formica countertop and a round stainless sink. I want to keep the same shape.
Has anyone tried this? If so, I would love to see how you did it.
mommythrice is offline   Reply With Quote
Old 11-24-2014, 05:26 AM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I replaced mine w: stainless Click image for larger version
Name:	ImageUploadedByAirstream Forums1416831987.203194.jpg
Cochese is offline   Reply With Quote
Old 11-24-2014, 07:42 AM   #3
1966 28' Ambassador
Originally Posted by Cochese View Post
I replaced mine w: stainless Attachment 227282
Very nice!
So, how did you remove the old one and how is the new one attached?
And it looks like you moved the toilet forward. What's going on there?
Old 11-24-2014, 03:03 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I removed tub Assy. When I did rear floor replacement . I had tub sink refinished while it was out, sink had a crack that was repaired at that time. Long story short, the crack reappeared after reinstallation,total PITA to remove sink after the fact! I used a Fein tool to cut rivets to remove sink from wall. If you have stainless sink made you will have to have at least a 3/4" lip turned upward that curves w/ wall in order to re rivet the sink on. This project was costly( sink fab)& time consuming ! Good luck... Brian
Old 11-24-2014, 03:10 PM   #5
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Btw, I cut toilet bench off while tub was out to gain a little more room, this required a complete re routing of plumbing lines that used to run under the bench. I got the idea from another forum member( Stole it!) I still don't like the sink over tub design, but I like the way the toilet area turned out. My favorite is the 67 model
Old 11-24-2014, 09:56 PM   #6
1966 28' Ambassador
It sure looks easier to use your sink. I hate bending way over to brush my teeth in my bath, but mine is all in great shape except for that sink top, so I'm going to leave it alone. I haven't looked at the rivets yet. I was planning on Corian counter top, so not sure how to attach it yet. Thanks the the info.
Old 11-25-2014, 04:16 PM   #7
1966 26' Overlander
Anderson , Indiana
I'm in the same situation mommy. My sink has a crack in it, and I don't think I can fix it easily. From looking at it, I think you will have to cut the rivets by cutting between the sink and wall. I've got another good sink to put in, but I am not looking forward to the project. I like the idea of a top with round SS bowl...
Kline1966 is offline   Reply With Quote
Old 11-25-2014, 06:20 PM   #8
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
You can take a putty knife around the wall/ sink perimeter and hammer it down to shear the rivets in half. The sink is held to wall w rivets. You'll also need to pull the drain basket to get it off. Remove plumbing from trunk access.
If sink is not broken try tub and tile refinisher. We have had good luck with the spray-on type from lowes.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
No water to sink or bath dogwood Fresh Water Systems 4 05-20-2008 09:09 PM
need new bath sink faucet KHarris Sinks, Showers & Toilets 3 09-05-2006 10:31 PM
leaky bath sink faucet maxandgeorgia Sinks, Showers & Toilets 1 08-05-2006 02:19 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Refurbish bath sink advise/71 Globetrotter LarryD Sinks, Showers & Toilets 8 04-03-2005 12:39 AM
