Old 08-14-2015, 04:21 PM   #1
2trackrr
1991 34' Limited
Waxahachie , Texas
Replace AC How much work is it
I need to up grade my 1991 Dometic 13,00 BTu AC and want to up grade to a 15,500 or larger AC/Heat-pump I need suggestions for units and opinions of how difficult of a job is it to do it myself.
2trackrr is offline   Reply With Quote
Old 08-14-2015, 04:41 PM   #2
1981 31' Excella II
New Market , Alabama
The hard part is getting it on the roof and the old one off. Two guys can man handle the old one off and the new one on. Don't you have two units on that trailer?
Perry
Old 08-14-2015, 08:47 PM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I just replaced mine. It's a pretty easy job if you have a way to get the old one off the roof and the new one up there. Fortunately I had access to a forklift. Nothing to it. Lacking some mechanical way to get them up and down, it would be a challenge.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-14-2015, 08:56 PM   #4
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
How handy and/or mobile are you? If you can get around without any problem, replacing the AC is a piece of cake. All you have to do is separate the bottom from the top, set it on a thick piece of cardboard or something soft but thick like an old sleeping bag that you can use to slide the old unit to the edge of the trailer, bear-hug it as you stand on a SECURE ladder, then SLOWLY come down off of the ladder. Reverse the process to install the new one.
I hefted mine onto my shoulder to go down and up the ladder.
If you are not handy or mobile, find someone who is and entice him/her with food and/or adult beverages, if they are so inclined. Save the beverages for AFTER the project is finished!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 08-14-2015, 09:26 PM   #5
1990 32' Excella
jonesboro , Arkansas
Ac
I rented a couple of scaffold sections from home depot.put them 2 high.with 3 walking boards.you can lift the ac up 1 level at a time. Then I put 2 2 x 6 from scaffold to top of trailor you can slide the unit onto the top that way. Good luck.
joel is offline   Reply With Quote
Old 08-14-2015, 09:35 PM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
2trackrr - it isn't quite as simple as it sounds. The new unit won't just drop into place of the old one, as the condensate drain (the trays that catch the condensate) are not the same. As well, the gasket is different. I had the a/c on my 1987 Excella changed at JC, and it wasn't a quick bolt off and bolt on. Yours is, like mine, a narrow body and does not have the flat center of the roof. Assuming you are still comfortable doing it yourself, look for a place to rig up an overhead winch for lifting and lowering the a/c units. While it is possible to bear-hug the unit like Paul did, remember that one slip on the ladder and the damage you can do to your rig and yourself may not be worth the attempt.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 08-14-2015, 09:44 PM   #7
PaulnGina's Avatar
Good Ol' , USA
Aw, c'mon..... where's your sense of adventure?!?! LOL!!!
Yes, you MUST know your limitations!
1987 Avion 34W
Old 08-14-2015, 09:55 PM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I was up on my roof today to replace a bad start cap. Whoever designed the A/C set up on mine must have had to work on them too. I don't want to change mine anytime soon, but when the day comes, it wont be too bad.
I have scaffolding but found a 14 foot ladder propped against the upper horizontal rivet line worked great and gave me almost complete access to both sides. If you have a friendly construction company close by that has a Skytrak, forklift, or medium trackhoe your life just became easier. You could do all the preliminary disconnects, and have a rope or chain already attached. Same for the new unit. Remove the screws and bolts, hook up and remove. Replace your new unit, attach the bolts and screws and drive it home to finish the install.
NavyCorpsman is offline   Reply With Quote
Old 08-15-2015, 10:43 AM   #9
2trackrr
1991 34' Limited
Waxahachie , Texas
Thank You all
Thank you for all your suggestions. The scaffolding sound the best. Ive been on my roof often and think having planks to walk on best. Does anyone know of a 18,000 BTU unit?
Thanks 2tranksrr
how much wind is too much Barry Parkof Awnings 15 04-04-2009 12:19 PM
How much is too much, or too little - 1962 Globetrotter? gduffydc 1960 - 1964 Globetrotter 3 01-07-2009 02:39 PM
How much damage is too much? kaulike Ribs, Skins & Rivets 8 01-20-2007 01:10 AM
Carbon Monoxide: How much is too much? Lotek General Appliance Topics 3 01-08-2005 06:06 AM
How much is to much garry Our Community 13 07-08-2003 03:53 PM
