Old 07-07-2012, 03:11 PM   #1
Runnells , IA
Repair avoidance
We've figured out that we never received the operating manual for the Penguin heat pump on our 2002 Safari and can't find it online. We've rarely used the A/C (maybe twice!) What should we be doing in terms of maintenance to avoid problems?
sid42 is offline   Reply With Quote
Old 07-07-2012, 04:01 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Use it regularly. Clean it once a year and clean the filters regularly....even if you don't use it.
Old 07-07-2012, 05:49 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I agree! Turn it on once a month and let it run for 20 minutes or so.
The auto industry has tied the air conditioning into the defrost mode in order that the AC gets operated even in the winter months. AC failures have been reduced significantly with this method.
Old 07-07-2012, 05:53 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Is this what you need?
http://dometic.com/ccd5e367-69f8-42e...d5a32886.fodoc
MICHAEL
