Old 01-07-2008, 12:00 AM   #1
Hypnotist
jjhypnotist's Avatar
1982 28' Airstream 280
las vegas , Nevada
Exclamation Renovation Help!!!
Hi guys any help would be greatly appreceated! I am renovating my 1982 Airstream 280 turbo diesel and am running into a challenge.
The reneral gist of the renovation was and is to update the interior by removing the original carpets and putting hardwood down refinishing the bathroom and installing new trim. throughout the rv.
Once I got started I found many old waterspots on the plywood throughout the MH however the floor was sound until I removed the carpet around the cockpit area.. On both sides in almost identical spots I seem to have a leak one next to the wall on the passenger side and once I pulled the carpet up, one on the drivers side. The passenger side is fine though damp and I throughly sprayed the area with bleach to kill and mold or other bacteria and it is drying nicely...... The drivers side on the other hand I can stick a screwdriver through.. Not good....
Now interestingly enough the plywood here is laid on top of a piece of steel and looks to be screwed in I will post pics of the screws and the area...
Has anyone ever removed these before or know the procedure to do so.. it looks as if there are three pieces of wood one on either side of the doghouse and one in front they all have these massive phillips head screws attaching them it seems. DSC05525.JPGDSC05528.JPGDSC05529.JP
The floor in general is getting sanded down and is going to get a coat of thompsons water seal then polyurathane before I lay the the new hardwood floor and to protect it from any further damage.
Thanks guys!
Justin James
ID:	52161   Click image for larger version
jjhypnotist is offline   Reply With Quote
Old 01-07-2008, 04:31 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Originally Posted by jjhypnotist
...The floor in general is getting sanded down and is going to get a coat of thompsons water seal then polyurathane before I lay the the new hardwood floor and to protect it from any further damage.
Thanks guys!
Justin James
Thompsons does not recommend their products for interior use. I got this information straight from their Tech Support several years ago. The polyurethane sealer is really all you need if you want to seal it.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
'77 Sovereign renovation thenewguy 1974 - 1979 Sovereign 18 12-14-2009 02:28 PM
'65 ovrlndr renovation 65overlander 1965 Overlander 12 11-05-2006 10:11 AM
Bambi Renovation SSanders Member Introductions 2 10-18-2006 08:34 AM
78 Excella Renovation ! ALTE797 Upholstery, Blinds, Walls & Interior Finishes 5 05-19-2006 06:19 AM
New pics of my renovation simonhanbury General Interior Topics 7 01-30-2006 06:25 PM
