Old 07-10-2016, 07:41 AM   #1
1976 Argosy 26
Henderson , Kentucky
Images: 21
renovation 76 argosy
Trying to remove kitchen cabinet ie furniture. Needing need to confirm my unfortunate dilemma finding the original avocado countertop is wider than door opening. So I need confirmation disassembling is required and there is no secret for removal. Tell me it is not so. Why design that way? Adds much time to removal for storage or reinstallation. Strange.
Ky76Argosy is offline   Reply With Quote
Old 07-10-2016, 08:40 AM   #2
Trnpk Crsr's Avatar
Baltimore , Maryland
My parents had a '75 Argosy. It too had the avacodo green counter top. An Airstream/Agosy service tech told my dad that everything in the trailer was designed to come through the door, even the refrigerator.
Trnpk Crsr is offline   Reply With Quote
Old 07-10-2016, 09:42 AM   #3
1976 Argosy 26
Fair Oaks , California
Counter top must come off . The base cabinet should come out but might require some minor disassembly.
Argosy Heir is offline   Reply With Quote
Old 07-10-2016, 12:35 PM   #4
1976 Argosy 26
Images: 21
counter top depth
Re-measured and yes top must come off. Top 27" and door 26". Still strange that airstream design with those dimensions.
Lowe's Formica counter top blanks come in standard 25". Does anyone know if that fits original base or how to modify base or counter top?
Old 07-10-2016, 01:08 PM   #5
1976 Argosy 26
Cabinet base needs to be modified if using Lowes type counter top. It is quite simple though. There is only one "side" of the cabinet . Remove enough of the side of the cabinet (the one where the magazine rack is ) to fit the shallower counter top . Slide the base closer to the wall. Gives a bit more floor space .
I also added a small microwave while moving things around.
http://www.airforums.com/forums/f420...ri-106409.html
Old 07-13-2016, 07:17 AM   #6
1976 Argosy 26
Images: 21
microwave installation
Great location idea.
Do/did you use gfi wall plug. Or an exterior plug cover for outlet?
What watt microwave recommend? Any issue or concern about low voltage with microwave use or voltage limits if running the appliances, refrigerator on electric, etc and 13500AC on a 4000 watt generator or if with AC start up?
Old 07-13-2016, 09:19 AM   #7
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
It seems that nothing was designed to be serviced after it was installed. Try changing out the kitchen faucets sometime. To get the furnace out of my 73 Argosy 24 the shelf above the furnace must be removed.
Gearheart is offline   Reply With Quote
Old 07-13-2016, 11:41 PM   #8
1976 Argosy 26
If you put a GFCI on your exterior outlet, you can use the load side and have protection. I drilled a hole in the plastic cover under the sink and used an on the wall wiring components from Home Depot. The microwave is a cheaper ,compact , Target version as I needed something small for that area . I am using a 2000 watt Yamaha generator without any problems . Of course no air conditioning
Old 07-20-2016, 08:21 PM   #9
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
All of my interior came out through the door with no issues.
AlbertaBound is offline   Reply With Quote
Argosy Motorhome Purchase & Renovation, What To Pay, What To Expect adamwright Argosy Motorhomes 3 08-31-2014 06:17 AM
New Argosy Renovation in Houston, TX argosy1.0 Member Introductions 4 01-05-2014 10:49 PM
1976 22' Argosy - Restoration (With a touch of Renovation) crabbey1 All Argosy Trailers 7 11-21-2013 08:13 AM
Renovation ideas needed for 28' Argosy motorhome - contemporary bosube Interior Restoration Forum 3 12-22-2010 06:02 PM
Renovation Finally Begins - 28' Argosy MH Silver Bullet Don Landis Argosy Motorhomes 2 09-20-2009 10:34 PM
