Old 10-22-2013, 11:34 PM   #1
No. 13's Avatar
2012 25' FB Flying Cloud
Orange County , California
Removing the shower door from the wall
Has anyone removed the hinged side of the shower door frame from the wall. Only 3 screws hold the U-shaped channel (with long hinge) to the wall mounted frame, but it is stuck on tight...looks like a lot of silicone was used. It is a very flush tight fit and I can't pry it from the wall. Any suggestions? Thanks.
Gene
No. 13 is offline   Reply With Quote
Old 10-23-2013, 01:52 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my shower door is different than yours, but mine was stuck on with two sided tape. [no screws on mine] The factory used white tape and I replaced it with 3M automotive gray/black two sided tape. The white tape will separate in the middle, but is hard to get the glue sides cleaned off.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-23-2013, 07:36 PM   #3
No. 13's Avatar
Thanks Bob. This thing is like a rock...thought it would just slide off. Not sure what is holding it on so tight...I may try a heat gun this weekend to get it loose. Shower door came out of the frame and I need to fix it with the frame off then re-hang it. Trying to avoid a trip to the dealer. Oh well...another project.
Old 06-27-2019, 07:39 PM   #4
2014 28' International
Sonoma , California
Removing shower door
Hey - I'm going through this right now. How did you solve your problem? Did you ever get it off?
RamblinRose1 is offline   Reply With Quote
Old 06-27-2019, 08:02 PM   #5
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
Ours collapsed last fall on the way back from New England. I had a rather long list of repairs needed due to rough roads in New Brunswick and New England so I had "my RV guy" look into it. I'll have to post some pics as I can't really describe what he did, but it worked. It is supported more now from below. The aluminum rail on the hinge side failed on mine (at the top) where it was attached to the top stile. Just ripped way. It was only supported at the top and bottom by plastic spacers and bushings.
Oh, and he didn't have to pull the door from the wall.
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Old 07-30-2019, 08:50 AM   #6
2012 25' Flying Cloud
Oak Ridge , North Carolina
Shower door frame removal
Did anyone get a solution to removing the shower door frame? I am replacing my collapsed shower door with the STOETT vinyl one. Have tried heat gun but to little success.
damascus is offline   Reply With Quote
Old 08-03-2019, 07:20 AM   #7
Sonoma , California
I did have success removing mine with a heat gun and a lot of patience. Remove the screws and there is double sided tape that is holding it place. A lot of slow heat and a screwdriver to torque it off worked for me. I wish you the best of luck!
