Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-12-2009, 09:59 PM   #1
Profile:  1994 30' Excella
Joliet , Illinois
Airstream Registry
Removing the old numbers and stars
We bought our first A/S last summer from a wonderful couple in Alabama. Now we have joined WBCCI, received our identical numbers, but the old ones seem to be "one with the unit" presently. Can anyone suggest how I should best remove the old and clean the dome to place the new numbers?
Would appreciate any and all suggestions because Goop nor peanut butter worked.
Best,
Lucy749
30' 1994 Excella A/S
Lucy749
Lucy749 is offline   Reply With Quote
Old 06-12-2009, 10:21 PM   #2
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Airstream Registry
Hi,
Heat Gun.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 06-13-2009, 12:27 AM   #3
Foiled Again's Avatar
Virginia Beach , Virginia
uh, make that a hair dryer - a heat gun might be too hot and stretch the aluminum. Also all adhesives seem to hate either WD-40 or plain vegetable oil. Put a bit on a rag and leave it on the edge of a number for at least 10 minutes. If you can, get one corner starting to curl. That helps a lot. You can get plastic razor blades, or use the edge of a credit card to work around the edges of the numbers too.
Good luck, Paula
VA-6 yah!
HONK if you love Jesus,
TEXT if you want to meet him personally.
Old 06-13-2009, 04:18 AM   #4
GStephens
GStephens's Avatar
Profile:  1982 31' Limited
Hamilton , Texas
Like Foiled Again said, use a hair dryer and lots of patience.
GStephens
GStephens is online now   Reply With Quote
Old 06-13-2009, 05:45 AM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
1967 24' Tradewind
Estancia , New Mexico
I used a heat gun with no problem, but if you only have a hair dryer use it. I also used WD40 which had no effect. Paint stripper will soften the vinyl, remove the glue but also remove the clear coat. You will still have ghost images of the old numbers. The only way I found to get rid of them completely is polish the hell out of them. Then, of course, you will have very shiny ghost numbers.
get off the road hippy
Lumatic is online now   Reply With Quote
Old 06-13-2009, 07:26 AM   #6
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Steam Iron, and a wet rag. works like a charm.
the problem w/ solvents is that they don't come in contact with the glue; its being shielded by the vinyl; you need to remove the sticker in order to get the solvent on the glue...and if you could do that, you wouldn't need the solvent!
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-14-2009, 08:12 AM   #7
Joliet , Illinois
Airstream Registry
Originally Posted by ROBERTSUNRUS View Post
Hi,
Heat Gun.
Brilliant! Thank you, and we happen to have one sitting in a box in our basement!
Lucy749
Old 06-14-2009, 08:14 AM   #8
Joliet , Illinois
Airstream Registry
Thank you, thank you! We appreciate all your suggestions, and will try them all and report back.
Lucy749
Lucy749
Removing Numbers and Decals Phil Tribby Cleaning, Stripping & Polishing 32 07-24-2009 06:08 AM
Shootin' Stars Crusty Off Topic Forum 3 12-12-2008 04:45 PM
Removing old WBCCI numbers? KHarris Cleaning, Stripping & Polishing 8 07-14-2007 11:25 AM
WBCCI numbers and 5 Red Stars MacStreamer WBCCI Forum 21 07-09-2006 03:45 PM
Removing Wally Byam Numbers? 25-Feet99 Cleaning, Stripping & Polishing 6 02-16-2006 08:19 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
