Old 06-12-2014, 08:32 PM   #1
1976 Argosy 26
Manzanita , Oregon
Removing the Air Conditioner and adding a skylight
Hey guys, new here. Just bought a 76' argosy and removed the interior, painting, fixing the floor, and on my way to adding a whole new setup. Having a great time. (ok fine, I'm fixing the floor tomorrow so I reserve the right to retract that having a great time statement.)
Question? I really want to pull off the air conditioner and replace it with a skylight. Can anyone direct me to a link or offer advice as to how this might be done. I'm a little intimidated by the notion of building the whole curb and interior detail out of aluminum. Is this something I could do partially in teak? Are there any prefab kits that make it easier. Not sure where to start. anything is helpful.
Brian Schulz is offline   Reply With Quote
Old 06-12-2014, 09:40 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Are you adding a different kind of AC somewhere else? By the way, my last name is also Schulz.
Skatiero is offline   Reply With Quote
Old 06-13-2014, 08:43 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bdian,,
Remove AC. secure drain and power lines in case you reverse direction.
Measure opening... go to sheet metal shop and have them build a "curb ". Make it same dimension as other roof curb.have joints welded..(a must) .
Use C channel aluminum to support gap between roof and ceiling. Secure with Olympic rivets. Next mount curb and Maxim skylight.
Peace and Blessings..
Channing
WBCCI# 30676
1969 Overlander replacing air conditioner with skylight lionheart Roof Vents, Skylights & Fans 21 11-12-2015 04:52 PM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Removing air conditioner 2vets Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-13-2010 11:43 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
