Old 10-14-2019, 11:40 AM   #1
2015 25' FB Flying Cloud
Minnetrista , MN
Removing shower door
A screw holding the shower door frame together seems to have sheered off. The door now sags and the frame is separating. My immediate problem is that I can't seem to remove the shower door to repair it. I've removed the 3 screws on the inside of the shower but that hasn't loosened anything (unless I need more muscle). I don't see any other fasteners that will allow it to be disassembled. Any suggestions?
One picture is a closeup, the second is the same view but further away.
2015, 25'FB, Flying Cloud.
Name:	shower door closeup.png
ID:	354233   Click image for larger version
Wesair is offline   Reply With Quote
Old 10-14-2019, 12:31 PM   #2
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
This is a known problem by Airstream caused by supplier using SS screws which are 1/8" too short; we replaced ours but the screw thread was still in the extrusion when it broke off; could not get it out so they sent me a complete door assembly! We simply removed the screw on the new model which is longer and put it back together without taking off the enclosure in the AS. Also installed a new bushing in the bottom hinge....anyone want to purchase a brand new shower door??
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 10-14-2019, 09:04 PM   #3
Minnetrista , MN
Thanks, I'm not too surprised. Any idea how to take the assembly apart? It looks like the screw is broke off and I don't see any way to get at it without taking the door apart.
Old 10-15-2019, 07:31 AM   #4
gypsydad's Avatar
Ours opened up while driving and it "fell out" half off the "hinge" area, but still connected to bottom frame/hinge, hanging on with the lower hinge/extrusion. So I was able to "pull off" the upper frame/extrusion since the glass door was exposed outside the frame and I could see where the screw was broke off inside the extrusion. I was shipped the "new replacment" door from AS so I just took off the new top extrusion with the new screw, removed the screw and installed it on my glass door, reinstalled the screw into the frame. This door is too heavy for an RV in my opinion...residential useage. AS is aware and has lots of Teflon spacers and new longer steel crews here in Jackson Center we found out yesterday...
Removing the shower door from the wall No. 13 General Repair Forum 6 08-03-2019 07:20 AM
Has anyone had a custom lucite or clear plastic folding shower door made fro shower? Driftin Di Sinks, Showers & Toilets 2 08-09-2017 08:34 AM
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 10:10 PM
Removing Shower Door Cleveland Windows, Doors, Locks & Vents 0 01-31-2014 01:30 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
