Old 08-08-2014, 04:27 PM   #1
1984 31' Sovereign
Stockbridge , Georgia
Removing crank up TV antenna
Hi everyone.
Has anyone removed their crank up TV antenna? I'm thinking I'm not ever going to watch network TV while camping, and the antenna might as well be gone before it gets caught on something and ripped off or blown off in a storm.
How much of the antenna should I remove, ie leave the base? What should I use to plug the hole in the roof?
Thanks everyone.
Mike
Mike
1984 Sovereign 31
2002 Chevrolet Silverado 2500HD
slantflat is offline   Reply With Quote
Old 08-08-2014, 05:01 PM   #2
OldVwHunters's Avatar
1969 18' Caravel
Northwest , Missouri
Images: 35
I removed all of mine and sold on Craigslist, as I won't watch TV anywhere, until they make some new episodes of Doc Martin. Stuffed the hole where the shaft went through with insulation. Just have a temporary patch up top until I get a permanent cap made up. Thinking I'll put a smoke detector on the ceiling to cover the hole inside.
OldVwHunters is offline   Reply With Quote
Old 08-08-2014, 06:21 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I just removed the antenna bars and left the crank mechanism for now. It doesn't leak. Like you, I didn't like having that thing up there waiting to catch a low tree branch some day. And we were not using it at all.
Ten minutes with a hacksaw is all it took.
David
Old 08-08-2014, 06:38 PM   #4
SafariBez's Avatar
2014 30' International
Corsicana , Texas
We use air television quite a lot. Sometimes it is much better than RV park cable. What is the upside to removing this device?
SafariBez
SafariBez is offline   Reply With Quote
Old 08-08-2014, 06:56 PM   #5
1986 31' Sovereign
Miami , Florida
At home, I get over 40 channels of digital tv (excellent quality) - and often use it on the road when I just don't feel like getting out the satellite dish. I can't imagine removing it unless it is leaking. A low hanging branch is a far greater danger to your a/c shroud than to your antenna...
Mikr
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 08-08-2014, 07:26 PM   #6
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Two words: Resale value!
SilverGate is offline   Reply With Quote
Old 08-09-2014, 05:15 AM   #7
1969 18' Caravel
Images: 35
What's the up side? No chance of evil mind manipulating thoughts and ideas being injected into the brain waves. No chance of squirrels perching themselves on it waiting to throw walnuts at you as you step out the door. No chance of an alien ship hovering above, pointing and laughing at the antenna poking out of your trailer instead of your head where they all know it belongs. The best part is that extra 6.247 miles per gallon you'll gain while towing without the extra weight and wind drag (Your actual results may vary due to driver error, and or meteorological conditions). When lightning hits the antenna on someones trailer in the campground it won't be yours. Less acidic bird poo on the aluminum.
Old 08-09-2014, 05:41 AM   #8
blickcd's Avatar
Milford , Ohio
I second leaving it on for resale value.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 08-09-2014, 06:49 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I suppose if you never use TV at home you may not use it on the road. Otherwise hang onto it for awhile, you may occasionally use the HD broadcast signals that beat the crap out of most fuzzy campground cable hookups.
Doug and Cheryl
Old 08-09-2014, 07:12 AM   #10
1969 18' Caravel
Images: 35
If you go to sell the trailer the prospective buyer will be unknowingly drawn to yours over the others because of it's sleek uncluttered appearance. By the time they figure out it's missing they'll be so calm and relaxed from the lack of television stress they will send a card thanking you for bettering their overall well being. Go on, do it! Join the anti-antennite revolution!
Old 08-09-2014, 09:30 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I took mine down on both trailers. The little square interior antennas work pretty darn well.
Frankly both of my antennas were pretty trashed and not worth the time to repair or risk of water leaks.
I simply applied a patch over the hole in the exterior skin.
Old 08-09-2014, 10:19 AM   #12
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'll interject an alternate idea. I'm actually replacing my old deteriorated TV antenna with a dual Wi-Fi antenna setup. I've attached two Yagi antennas to the existing bar, which I shortened considerably.
I'll be keeping the crank-up and directional functionality. Now all I need is a WPA passwrod cracker, and I'm all set!
Old 08-09-2014, 11:25 AM   #13
1984 31' Sovereign
Thanks everyone. Even though I'm not even going to have a TV in the trailer, it does seem ashame to just kick it to the curb. I mean, I remember when every house had a TV antenna, and rabbit ears, etc. I'm sure it will get repurposed somehow.
Mike
1984 Sovereign 31
Old 08-09-2014, 11:48 AM   #14
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I've often thought of replacing the TV antenna with something for the WiFi, but like others on here, I am concerned for the re-sale value. Better to add than replace or remove I think.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
It seems my crank up Antenna doesn't work Re-Pete Audio, Video & TV 23 04-22-2013 08:57 PM
Crank assembly, Delta Antenna,1990 345bill Classic Motorhomes 4 07-24-2012 06:47 PM
Roof crank up antenna wire goes where ??? dryenko Audio, Video & TV 10 01-17-2012 07:54 PM
Crank-up antenna/Digital era Darel Argosy Motorhomes 17 11-12-2011 06:35 PM
Remove Antenna Crank bwaysteve Phone, CB & Ham Radio 3 01-15-2010 03:21 PM
