Old 10-26-2015, 08:09 AM   #1
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Question Remove Duo Therm 66117 furnace
I have a small Duo Therm 66117 furnace in my truck camper. The fan
motor is really sick, so want to take the furnace out to repair the motor.
Problem is, this camper lived in Florida for years and the outside vent
I believe has to come off, is well rusted in. Have soaked it with "Kroil"
several times to no avail.
any none destructive suggestions appreciated.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 10-26-2015, 05:55 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Had an issue like this when I had a '94 LY motor-home that had been in FL. It took about 10 days of liberally spraying WD-40 on the bolt that held the inner and outer assemblies together and trying to unscrew the nut. Even did a bit of careful heat from a propane torch. As I was about to give up, the nut loosened and came off.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Duo-therm wall furnace - 1965 max7 1965 - 1969 Globetrotter 1 08-15-2012 10:53 PM
Sourcing older Duo Therm Furnace parts smittyb Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-28-2009 08:16 PM
Duo-Therm Furnace (MH) repair or replace? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-30-2003 02:47 PM
? re Duo Therm Furnace - 1968 GT Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-21-2003 08:52 PM
Parts for Duo-Therm 900 series furnace? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-22-2003 02:45 PM
