Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-16-2015, 06:53 AM   #1
Unka Jack's Avatar
Fonthill , Ontario
Remove battery box, or leave it on for shell off??
Almost ready to lift the shell off my '73 Overlander this weekend. Just wondering from those who have gone on before. Is to okay to leave the battery compartment on, or should I drill out all those rivets and remove it prior to lift off?Click image for larger version
Name:	ImageUploadedByAirstream Forums1429188810.895181.jpg
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
Old 04-16-2015, 08:00 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You will need to drill out the rivets, for two reasons:
1) As I recall, the frame of the battery box that wraps underneath the trailer is too wide to pass through the hole in the subfloor for the battery box, so it will hang up during your lift.
2) When I had pulled the frame out from under the body, I just lowered my body down to the ground and put a wooden block under each vertical rib to help support it. If the battery box is left riveted to the shell, then the shell will have to be supported high enough to keep the battery box from getting squashed.
good luck!
Old 04-16-2015, 08:34 AM   #3
Unka Jack's Avatar
Fonthill , Ontario
Oh joy, more rivets to drill. At least I can see these ones. Just spent the last 3 hrs chiseling out the roadside edges. For some unknown reason, there is a double outer skin with the outer one covering the bucked rivets. Doesn't look like a repair, looks like it came from the factory like this. Maybe they goofed up in assembly and had to fix it there.
Cheers,
Jack
73's VE3ZPW
Old 04-16-2015, 10:08 AM   #4
Unka Jack's Avatar
Fonthill , Ontario
"And the survey said...."
Name:	ImageUploadedByAirstream Forums1429200468.669891.jpg
Cheers,
Jack
73's VE3ZPW
Old 04-16-2015, 12:17 PM   #5
Belegedhel's Avatar
Houston , Texas
Hmmm. On my '73, the shell was bucked to the c-channels, and then the banana wraps/bellypan edges were brought up and overlapped (covered) the line of bucked rivets and were popped in place. They then pop riveted a rub-rail (piece of trim) on there to cover the overlap and make it look pretty.
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
