Old 03-18-2016, 11:46 AM   #1
1972 27' Overlander
Lamar , Missouri
reinforced frame
on my 72 LandYacht, I noticed that there was a factory fix to strengthen the rear frame. I have 2 patches behind the wheels. Would this be the location of the frame strengthening?
(Also, thanks for this Airforum, I have had my questions answered quickly and expertly, I have read most of all the discussions!)
walleye001 is offline   Reply With Quote
Old 03-18-2016, 12:40 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Those are the spots that are reinforced so you can jack up the trailer. The frame reinforcement to prevent bending between the axles is a fishplate type metal plate bolted to the axle mounting plate that extends down from the body of the trailer. The Fix also included cutting into the back of the trailer and putting a reinforcement in the C channel and additional bolts holding the body to the frame. The patch that was installed to cover the access holes are called elephant ears. It is easy to identify a trailer that has the recall repair done by the presence of the elephant ears. I have seen them on many Airstream trailers.
I Need Photos/Diagram of Reinforced Mercedes Hitch jonnie3 Hitches, Couplers & Balls 8 05-05-2015 01:14 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Fiberglass Reinforced Panels........ RV H-D Lady Sinks, Showers & Toilets 2 11-09-2010 07:15 PM
Fiberglass Reinforced Panels........ RV H-D Lady Upholstery, Blinds, Walls & Interior Finishes 3 11-07-2010 05:14 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
