Old 05-27-2019, 02:15 PM   #1
ljaecks's Avatar
1962 22' Safari
1964 26' Overlander
1965 26' Overlander
Wenatchee , Washington
Reinforce roof for AC-62 Safari?
Im looking to add an AC unit to my 62 Safari. Ive been reading about the importance of reinforcing the interior roof structure to support the added weight. Heres a picture of the opening where I plan to install the AC. I have the interior skin removed so now would be a good time to do something.
Does it look like I need reinforcement? My uninformed assessment would be no but, if so, I want to take advantage of the situation. :-)
Thanks in advance!
Laura
ljaecks is offline   Reply With Quote
Old 05-27-2019, 06:30 PM   #2
DFlores's Avatar
1968 22' Safari
Buda , Texas
We added 1x2 wood inside of aluminum frame as AC mounting will squeeze the aluminum framing
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 05-27-2019, 07:20 PM   #3
1976 24' Argosy 24
Milford , New Jersey
Look up the rough opening requirements of your particular ac unit. the 14x14 inch opening is where the reinforcing is needed. Yours looks good but the ribs may not fall where needed, in which case you would need to add some ribbing. I used 1 1/2 c channel. Just make sure you tie any ribs that you add into the existing framing. If the existing ribs are 14 inches apart your good.
Gkiesel is offline   Reply With Quote
Where to reinforce the hitch in N. California? bono Tow Vehicles 0 07-06-2015 02:57 PM
Frame repair and reinforce dkrukosky Repairing/Replacing Floor &/or Frame 45 10-09-2012 01:27 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
using fiberglass to reinforce shower corner charlie tuna Sinks, Showers & Toilets 3 08-31-2006 10:21 AM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
