Old 03-26-2016, 08:51 AM   #1
Plasma800's Avatar
houston , Texas
Reimbursed for warrant work?
I'm curious if anyone has paid for repairs out of pocket and then received reimbursment from airstream under factory warranty.
I have a small list of items, but would prefer to use Bob Jones RV who says if pre-approved by AS I can be reimbursed.
Anyone have commentary on this?
Alternate option is to go to Buda, or A&P
Title supposed to say "warranty"
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 03-26-2016, 09:15 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
A & P Vintage Trailer Works in Paradise, TX is an authorized Airstream repair facility and can do Airstream warranty work. They have done all of the extensive modifications to both the Classic and the 23D as well as some warranty parts replacement.
We replace all the defective parts with the ones Airstream should have used to begin with, like brass cabinet catches and proper electrical outlets. The work is done correctly the first time.
Give Paul Mayeux a call to discuss your situation - (817) 919-3651.
Old 03-26-2016, 09:25 AM   #3
Plasma800's Avatar
houston , Texas
Sounds good I appreciate the nod towards them. I also understand they could probably swap my charger and maybe even add a little solar.
I can tell you my door needs some adjusting that's for sure, and that metal popping sound as you walk past the kitchen drives me nuts.
'15 27fb Signature
Does my intended usage warrant going with diesel? Danattherock Towing, Tow Vehicles & Hitches 168 08-10-2015 05:38 AM
Work Platform for Roof Work Bubba John Roof 18 08-02-2015 09:16 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Prep Work vs Finish Work Nolavalkyrie Vintage Kin 5 10-03-2013 03:11 PM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
