Old 08-18-2016, 05:29 AM   #1
1986 25' Sovereign
Cincinnati , Ohio
Regular vs Aluminum Rim
I just recently looked at my spare tire on my 86' 25' Sovereign. It was a real pain getting it out from under the trailer and noticed that it has a regular car/tire rim rather than a matching aluminum rim like my four other tires on the AS. This may be a dumb question but will this spare rim fit on the wheel or will I need to replace it with an aluminum rim?
Thanksin advance
Steve
Ssmookler is offline   Reply With Quote
Old 08-18-2016, 05:35 AM   #2
1986 25' Sovereign
Cincinnati , Ohio
I meant to title the post Regular vs Aluminum Rim. My fingers were on the wrong key
Old 08-18-2016, 06:22 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You can use the steel wheel but you will find the two piece Airstream nuts will not tighten up on the steel wheel. The Aluminum wheel is thicker that the steel wheel and the closed end nuts will bottom out. You need to buy some open ended steel nuts at auto store and keep a set in the trailer. We had the problem occur at the WV rally. Airstream should supply them, when they deliver the trailer. They should be smarter than they demonstrate.
Old 08-18-2016, 07:33 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Good heads up. I had not even thought of that issue.
MICHAEL
Old 08-18-2016, 07:42 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The lug nuts for my Safari's aluminum wheels work fine with my spare steel wheel.
The two piece lug nuts work fine on the steel wheels on my Excella.
Check out the fit before buying new.
I had my first flat on a trailer last fall, after 40+ years of towing. I never considered the lug nuts would not work with the spare. Guess I was lucky!
Alan
Old 08-18-2016, 08:21 AM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Fixed that for you
Stephanie
Old 08-19-2016, 05:59 AM   #7
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
One thing that I carry along with spare lug nuts are a couple of studs. I've never needed them but have heard of one getting stripped.
Streamracer is offline   Reply With Quote
Old 08-19-2016, 07:30 AM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've had the steel wheel on when I swapped out a set of tires years ago. The steel wheel supplied as the spare cinched up just fine with the existing nuts used by the Alcoa wheels.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-19-2016, 10:42 AM   #9
2017 27' International
Canfield , Ohio
Just a note, I recently replaced all five tires on my new trailer. The steel rim for the spare would not balance. In fact, it was way out of "round" and wobbled on the tire machine. The mechanic tried everything thinking it was the way it was mounted on the machine. After isolation the problem, they proved to me the wheel was way out of line and could not be balanced. Cheap china steel rim.
Has anyone put an aluminum wheel on the spare and does it fit OK on the rack underneath the trailer? I had a heck of a time removing the steel wheel. Put a few scratches on it. Am I going to have the same problem with the aluminum wheel?
2017 Airstream International Signature 27FB Twin
turk123 is offline   Reply With Quote
Old 08-19-2016, 01:05 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
Aluminum rims are particularly prone to corrosion from road spray when used as frame mounted spares. I would stick with a steel rim.
Old 08-20-2016, 09:20 AM   #11
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
You need 1/2" x 20 threads per inch lug nuts with a 3/4" hex outside
Note, the two piece Airstream nuts are junk, you should replace them with a solid lugnut. Something like Gorilla 41188 or equivalent.
Greg
greghoro is offline   Reply With Quote
Old 08-20-2016, 10:45 AM   #12
1966 24' Tradewind
Kansas City , Missouri
So, what tires have you been rolling on for those 40+ years?
Slats is offline   Reply With Quote
15" rim vs. 16" rim ? Easyrider06 Tires 154 12-18-2015 04:18 PM
Proper wheels--trailer vs. regular armycot Wheels, Hubs & Bearings 11 05-20-2005 11:32 AM
SS Polish for sale, regular price Stefrobrts Commercial Listings 0 09-10-2003 10:30 AM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
