08-27-2012, 10:42 PM
2011 28' International
Enumclaw
Refrigerator seals too tight ???
Hi....the fridge on our 2011 AS...seals WAY too tight!! It has some sort of funky dig your fingers deep in the side of the door and then stand on the other side and jerk, jerk, jerk to get it open. Surely there has to be a better way. Has anyone replaced the door handles on their Domestic ??? Thanks in advance!
08-27-2012, 11:29 PM
1988 32' Excella
Bonita
This may sound insulting but that's not my intent. Do you realize that the handles have a latch built into them to keep the doors from opening while traveling? Maybe your ripping the latch open. a gentle squeeze of the handle should release the latch and open the door.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
08-28-2012, 12:46 AM
Salem
, Oregon
Hi, squeeze the release handles.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-28-2012, 06:55 AM
Enumclaw
Hi...no insult taken. We understand the purpose of the door handles...but there is nothing to squeeze. The handles are flush to the door and in order to open them you have to reach in behind them and push the latch that is keeping the door from opening. But the door has sealed sooooo tight....you have to wrangle the door open. You can hear the thing sealing as soon as you gently move the door to close. A high pitched squeal starts...and next thing you know it's a vacuum lock. I want real door handles....is that something that can be changed out ?
08-28-2012, 07:22 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
My 2005 vacuum locks also. No way short of a paint scrapper are you getting my door open within 20 seconds of closing it. This is especially true for the freezer.
I consider it a feature!
08-28-2012, 07:42 AM
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
Our replaced frig in our 2004 seals tight as well and I feel it's just the way the things are designed. Somehow, we manage; however, the "Better Half" frequently comments about it. Good luck.
In dog years, I'm dead!
08-28-2012, 08:00 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
the freezer becomes hermetically sealed but the lower section should vent through the drain under the coils inside the fridge. check that the drain is not clogged between the inside of the fridge and the drip cup on the back of the fridge.
they must use the same gaskets as the ones that glue themselves to the windows ;-)
Ricky
08-28-2012, 10:28 AM
Oswego
This reminds me. I used 303 Aerospace on my windows 2 years ago and they have never stuck since. Try that on the fridge gasket?
-Rich-
08-28-2012, 10:51 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
it might work. give it a try!
Ricky
08-28-2012, 11:51 AM
Jupiter
I don't know if home versus RV options have mingled much, but refrigerator/freezer and freezers sometimes have the added option to pump as much warm humid air out of the compartments before it can cause frost via an electrical cycle that begins the moment the interior light goes off when the door closes. We had a freezer that would not be opened for better than a minute after closing the door from that feature. Could that be the squeal you hear after closing the door?
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
08-28-2012, 01:19 PM
2005 30' Land Yacht 30 SL
Oakland County
, Michigan
Tight Fridge/Freezer Handles
Our freezer seals tight like that. We have to wait a while after closing it before we can open it again.
The fridge does not seal as tight, though.
A good seal probably helps you to keep the cold in, but it sounds like this is a bit much.
Have you called the manufacturer?
BTW, dznf0g, what is 303 Aerospace?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
08-28-2012, 01:26 PM
Oswego
It is a non-greasy or oily protectant with UV protection. I use it in place of Armour All. Much superior as a protectant for most anything rubber plastic, fiberglass etc. Doesn't attract dust. Works well on those pesky window seals, the propane lid, Classic rear bumpers, plastic vent and skylight covers.....everything plastic. Great stuff. It was designed for NASA for space stuff for the UV protectant properties.
Amazon.com: aerospace protectant 303
PS, I'd use it all over on your glass MH.
-Rich-
08-28-2012, 01:43 PM
2012 25' Flying Cloud
Battle Lake
It's the pressure differential created when the warm air you let in by opening the doors cools and contracts. Indicates a real good seal, which is what you want.
To test this theory put a straw or something in the door when you close it so it will allow outside air to enter. Then open it. If it's loose, it's the pressure differential.
doug k
08-28-2012, 01:46 PM
Oswego
Doug, many of us have fridges open to the outside through the water drain tube. On those, I don't think it's a pressure thing.
-Rich-
08-28-2012, 02:52 PM
Battle Lake
You're right, there is a drain tube on the fridge, none on the freezer. The freezer sticks on mine from pressure. Could the fridge drain be plugged.
Try the straw thing.
doug k
08-28-2012, 06:58 PM
Oswego
doug k
On mine the freezer and fridge stick equally. I think it's a magnet/seal sticking scenario. Drain isn't plugged, ran like a river after a month of frost and ice buildup this summer.
-Rich-
08-28-2012, 08:39 PM
Battle Lake
daytripper, if it's just as sticky with fridge off (room temp inside) then it's a seal question. If it loosens with the fridge off (room temp inside) it's an air pressure differential.
doug k
08-28-2012, 08:57 PM
Enumclaw
Hi...to be honest we haven't tried it with the fridge off since we usually have it propped open to avoid any mold accumulation. Appreciate all the tips...will try some of them to see if it eliminates the problem. Along those lines...does anyone know if we can change the handles on the domestic ??
08-28-2012, 09:28 PM
1989 34.5' Airstream 345
Saint Petersburg
day tripper, my suggestion would be to go to the Dometic website. Seems they have all sorts of Q&A on the site.
Good Luck, Derek
