Old 09-23-2016, 10:11 PM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Refrigerator Problems
Just arrived to campground and refrigerator is not cooling on electricity. Was working fine this morning when before leaving home. What should I check first? 2015 International Serenity.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 09-23-2016, 10:17 PM   #2
streamer_a's Avatar
2012 28' International
Waukee , Iowa
We find ours getting up into the high 40s/low 50son a hot day after traveling without the A/C running. Shove a bag of gas station ice in there. It will probably come down overnight and be ok once you have the a/c keeping the trailer cooler.
streamer_a is offline   Reply With Quote
Old 09-23-2016, 10:36 PM   #3
Montgomery , Texas
It was 38 when we left home this morning after being on the road for 6 hrs and the system on auto, the temperature rose to 60 degrees. It's not cooling.
Old 09-23-2016, 10:40 PM   #4
streamer_a's Avatar
Waukee , Iowa
Yep - it'll come down. Takes hours. Just can't deal with being in 90+ heat.
Old 09-23-2016, 10:47 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Shouldn't get to 60 when towing even if 90F. Sounds like the propane burner didn't light after you unhooked shore power. Switch to propane and look inside the vent to see a burner flame. If the propane had been off for a while it may not have lit before the lighter timed out.
Kelvin
KJRitchie is online now   Reply With Quote
Old 09-24-2016, 09:18 AM   #6
1990 32' Excella
jonesboro , Arkansas
Are you traveling with frig on. Like KJR said the burner may not have lit if the lP was turned of at tank for a while. It can take several attempts for the lp but to purge air out and reach the frig. I have tried Up to a dozen cycles before the burner finally lighted. We do not turn the lP .tanks off til our trip is over so the burner comes on automatically when we unplug.
joel is offline   Reply With Quote
Old 09-24-2016, 09:28 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the frig was on gas while traveling and failed to light you should have a "check" light indicating there was a problem.
About the only way 6 hours of no refrigeration could raise the temp that much would be if the door was open or someone had put something quite warm in it just before you left home.
2004 Excursion 4x4
Old 09-24-2016, 09:32 AM   #8
KJRitchie's Avatar
2008 25' Classic
When my Dometic fails to light under propane I don't see any check light. I have to turn the fridge off/on then it tries to relight the burner. On the second attempt it lights.
When I bring it out of storage I turn on the LP and then run all three burners on the stove for a minute. This seems to help the fridge light up on LP better.
Kelvin
Old 09-24-2016, 10:16 AM   #9
HowieE's Avatar
Images: 12
Kelvin
When you turn the LP on after the trailer has been in storage do you hear gas flow? If you do you have a gas leak. Once the pressure in the system has dropped and been recharged by turning on the LP the stove burners will light quickly but the frig will not. The pilot orifice in the frig is too small to purge itself before the control board senses no flame and shuts down. Attempting a second or third time may allow it to light.
In any case if you hear gas flow when you turn the tanks on look for the leak.
2004 Excursion 4x4
Old 09-25-2016, 06:32 PM   #10
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
We run into this with LP (propane) and Natural gas logs sets in the fall.. We get a call from the homeowner saying the log will not light. They will have tried them several time with no results.
After talking to them we ask when were the logs last serviced and most of the time it been YEARS.. 10 or more most of the time.
We go out and I like to do a check so I push the pilot knob in and count to like 5 or so and put my lighter on the pilot.. Sometimes I see and hear the bad gas coming out of the pilot tube and just keep it pushed for another 5 sec and they start.
Lighting the burners on stove will purge most of the old gas out of system.. Most regulators will purge over time just a tiny bit so when you are in storage with the tanks off, the gas will bleed out and get diluted to the point it will not light.
best way to make sure it running is to check the hood on roof top to see if you make out the heat plumms radiating in the background or put your hand up there to feel the heat.
Now if you are on elec and not cooling the element may be burned out.. check it with ohm meter or amp probe.
Kelvin
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
Timeshare owner/user since '99
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 09-25-2016, 08:08 PM   #11
2016 25' Flying Cloud
Holly Springs , Mississippi
Kelvin's answer is spot on. You should be able to hear the burner if you listen at the ref. outside access door.
If it doesn't light the first time, recycle the refrigerator switch to "off" then back to LP. There's no "check" light on my unit. I just listen to be sure it has lit.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Refrigerator Problems - New Unit joshua32064 Refrigerators 35 08-02-2013 12:32 AM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 10:44 PM
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 07:02 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 08:25 AM
Refrigerator problems James Schmidt Refrigerators 6 05-10-2003 05:55 AM
