Old 04-25-2014, 05:35 PM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The fridge in my classic (Dometic 2807) has been problematic for the past several months. No light, no relight, endless check light.
This afternoon I removed the board and reignitor module.
I could not believe what I found! There were no fewer than 5 cold solder joints on the board, and darned near every crimp on spade connector was loose or not crimped!
I stripped, crimped, cleaned, and deoxited everything.....
Bam.... everything now works. I can switch from AC to gas and back with no check light! What a bummer I didn't spend the time before now!
If you are having issues, I strongly suggest the time spent with your soldering iron and a dozen new connectors.
Wahoo, consistently chilled libations without fear....
Old 04-25-2014, 05:41 PM   #2
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Sometimes it is the simple things. Congrats on tracking down the issue. I recently had a moment of angst when the coupler would not drop on the hitch ball, despite being lined up perfectly. Oh yea, need to raise the stabilizer jacks.
Cannonball is offline   Reply With Quote
Old 04-25-2014, 07:26 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Should have read Dometic....
Had the same thing happen this week... my Reese arms drpooed down and the coupler wouldn't seat.
Worked myself into a wtf lather!
Old 04-26-2014, 11:32 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Next day update...
All still good and cold!
This afternoons project is to swap the leds to blue and add an audible "check" alarm.
Cold is good
Old 04-26-2014, 12:55 PM   #5
Originally Posted by AtomicNo13 View Post
Next day update...
Cold is good
The reefer burner, depending on the amount of use, should be cleaned every few years, especially the orifice.
Old 04-26-2014, 05:01 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Yup, I use an ultrasonic tank to clean the venturi. It makes a difference. A little cleaning goes a long way. I believe the mercaptain oil goofs things up if not dissolved every then and again.
Compact Home Refrigerator or RV Refrigerator? Truebrit Refrigerators 26 04-05-2011 01:30 PM
Gas appliances in an RV - routine maintenance lbrodsky General Appliance Topics 9 09-06-2007 03:17 PM
Refrigerator Maintenance Navigator Refrigerators 1 03-18-2004 06:57 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
Mileage/Maintenance Log davidz71 Our Community 8 07-11-2002 07:23 AM
